  1. Hello, I am I guess a limited experienced newbie. I have been making DVD's for awhile. I use DVD Flick and it does what I need quite well. However I recently obtained some MKV files. DVD Flick will convert them for me, but no matter how many times I try it, there is a delay in the audio to viseo, and the timing between the two does not work correctly. When I play the original MKV files the audio and video are synced properly.
    I used some other converter, I forget the name at this time, and it told me that the MKV files had to use some special process (I forget the name) to be converted that had something to do with I think the timing. And I couldn't get it done.
    Can anyone tell me how to make the MKV files nto a DVD format, or AVI or something I can convert for free? Without a water mark?
    DVD Ripping? Nope.Moving you to our Video Conversion section.
    Try AVStoDVD.
  3. Member [_chef_]'s Avatar
    Nov 2002
    Germany
    Ah, that means?
    *** Now that you have read me, do some other things. ***
