So I downloaded the software without problems, I converted a file, but when I click on it, iTunes opens and does nothing. It still plays songs in the library, but it refuses to play the converted file. This problem has occurred with another software that I tried. I thought it was the software, but now I think it is some glitch in iTunes that may be causing this.
Any ideas on what's wrong?
Also, is there a way to convert a batch of files in ffmpegX?
What kind of file did you convert? (Source file - container, video codec, audio codec)
To what format did you convert? (Target file - container, video codec, audio codec)
ffmpegXs allows queueing of encodes: you do NOT have to wait for for the current encoding to finish to set up a new encoding.
For real batch conversions with ffmpegX, with the exact same settings, there is a solution by EmmGunn: Quick Batcher.
Mkv converted for iTunes Apple TV keeping 5.1
By swindmiller in forum Newbie / General discussionsReplies: 0Last Post: 1st May 2012, 22:28 -
Ripbot264 iPod format will play on iTunes but won't sync to iPod/iTouch?
By Riley007 in forum Blu-ray RippingReplies: 2Last Post: 31st Dec 2010, 01:04 -
DVD player won´t play converted .avi
By dexter30 in forum Video ConversionReplies: 4Last Post: 10th Dec 2010, 16:59 -
various movie files converted to play on dvd player
By SPORTSGUY88 in forum MacReplies: 4Last Post: 3rd Aug 2010, 11:25 -
File Converted by Handbrake (0.9.3) Using iPod Preset Won't Play on iPod
By GrayStrickland in forum Video ConversionReplies: 0Last Post: 8th Mar 2009, 21:56
