I have a problem with conversion of avi to VCD. When I try to convert som avi's with TMPGENC the sound gets lost. It's not on all, but a lot of them. The sound is ok when I play the avi with WMP, but when converting, nada. Right now I extract the sound with Virtualdub, and use the wav, I wonder if there is a simpler way? Might I be missing a codec?
TIA
"The future is no longer what it used to be"
Hi
Yes there is a fault in TMPGEnc when you try to convert some of the "new" DivX coded AVI's.
Click your right hand mouse button on the AVI and select properties, this shows the type of codec used, you will see its a new type and this problem will happen on all those movies using that codec.
Saving the audio in Vdub is the quickest way...
Sometimes!!!, you can start the conversion in TMPGEnc a little further into the movie (Source range) Start 50 frames, Sometimes it works !! -
Thanx a bunch! I thought I was doing something utterly wrong, so now I'm calmer.
"The future is no longer what it used to be" -
Actually I found a cure for my lost sound accidently (were trying the Subtitler filter): Frameserving from Virtualdub!
http://www.vcdhelp.com/virtualdubframeserve.htm
Just wanted to share this if you have the same problem, much easier than extracting the .wav!"The future is no longer what it used to be" -
Vdub 1.49 is much better, just save the AVI having tested for freeze frames (Junk) frames. But it also fixes any other simple problems.
my PC lost sound.
By volam1 in forum AudioReplies: 8Last Post: 9th Dec 2009, 04:37 -
Lost sound with .mod format
By mudracer-1 in forum Software PlayingReplies: 4Last Post: 6th Apr 2009, 22:50 -
avi to dvd lost sound
By makapa in forum Newbie / General discussionsReplies: 3Last Post: 2nd Feb 2008, 06:11 -
Lost Sound
By airgunforum in forum EditingReplies: 3Last Post: 22nd Nov 2007, 10:40 -
Lost sound on Pinnacle Studio 10 on PC.
By Balliol in forum AudioReplies: 0Last Post: 17th Jul 2007, 18:25
