Hi there,
I use a Canopus AVDC 110 to capture an analog TV Source (RCA input). The canopus AVDC110, is a Firewire device.
I am looking for a software which will enable me to caputre continous video in DV, breaking them into clips of an designated duration such as 1 hour. There are TV programmable (Soft VCR) Software but they support TV Cards which use Video For Windows Drivers, and I havent been able to use them with Firewire Devices.
I then use the Saved AVI files and covert them into H.264 / MPEG4 using Canopus Procoder.
Any advice is much appreciated.
LasithG
Thanks redwudz for the post and the Welcome!.
I will try that - it seems to be a very basic setup, where we dont have to set anything like the Capture Video Size (FrameSize-Resolution).
Will update once I try this.
BR
LasithG -
You are capturing DV data as it is transferred from the ADVS unit, so you have little control over what comes in. The resolution, codec and data rate are set by the DV standard. To WinDV there is no difference between the ADVC unit and a DV camera transferring from tape. It does not see the analogue source at all.
Read my blog here.
If you need info on how to use WinDV: http://windv.mourek.cz/
There's a interactive screen shot down the page a bit there that explains the controls as you 'mouse over' them. There are other similar programs out there, but WinDV works very well.
Real-time analog to DV capture - what is the right device to use?
By Serge_KB in forum Capturing and VCRReplies: 16Last Post: 24th Apr 2012, 12:33 -
Firewire device to computer with no Firewire
By dbuser2 in forum ComputerReplies: 11Last Post: 24th Sep 2010, 20:32 -
dvd recorder can't do automatic programmed recording
By dvdnewbie64 in forum DVD & Blu-ray RecordersReplies: 6Last Post: 5th Apr 2009, 16:40 -
Do I need a firewire card to capture video from my miniDV device?
By MPTESE in forum Capturing and VCRReplies: 8Last Post: 16th Mar 2008, 08:55 -
WTB Video Capture Device, External, Firewire, $250 Budget
By bpatters69 in forum Capturing and VCRReplies: 3Last Post: 22nd Jan 2008, 19:08
