Hi all, what format that ppl recommend? I would like to be able to fit all 82 episodes (in 8 DVDs) Asian TV series into a 16GB flashdisk so that I don't have to change DVD and playable in media player. i would like to be able to turn on the English subtitle as well. Thanks in advance. Also is there any recommended free software to do that. Thanks in advance.
Rip the dvds to iso using dvddecrypter, then convert to avi using fairusewizard and check that you want to extract the subs.
hanugro, are your DVDs actual DVD-Video discs, or data discs with video files? If the latter, what type of video files? And, does your player (which player is it?) allow external subtitle files?
Bwizzy: Handbrake wouldn't be able to do any actual DVD decrypting, though... and if this is for a DivX/Xvid-capable DVD player, Handbrake isn't able to output to that format (DivX/Xvid AVI) anymore.If cameras add ten pounds, why would people want to eat them? -
Hi all, thanks for suggestion. I bought the DVDs on the store so it should be a proper DVD with menu. Actually I have not open it yet. Ideally I would want to be able to turn on/off subtitle if possible.
I also have several media player from WD TV HD, RCA L100 full HD, and unknown brand made in china full HD with network jack. As this TV series is standard resolution, I plan to view it on WD TV HD.
How about the codecs? I think I should use H.264 as WD TV does not support RMVB.
Ripping problem with Windows Media Player 11
By singjai in forum AudioReplies: 10Last Post: 8th Sep 2011, 13:42 -
no audio when played in DVD player? help
By cpeters12 in forum Authoring (DVD)Replies: 2Last Post: 29th Jul 2009, 16:01 -
problems ripping to Media Player ?!
By paulpeople2476 in forum Media Center PC / MediaCentersReplies: 3Last Post: 17th Jun 2009, 10:37 -
ripping dvd with episodes to media player
By pace508 in forum DVD RippingReplies: 9Last Post: 5th Nov 2008, 11:38 -
V-CD: Both Sound Track are played in Media player classic
By cordeliamars in forum AudioReplies: 10Last Post: 28th Aug 2007, 10:25
