I had my Canon Xh A1s for about 2 months now. So far I love my camera but the only problem is the grain/noise. I spent hours searched forums for possible solutions but none of them seemed to help. Everyone told me to change the gain to -3dB but that didn't work.
Here are my main settings:
24F
Manual
Auto Focus is off
ND Filter is off
I tried 1/24, 1/48 & 1/60
AGC is off
AWB is off (I reset the white balance before I film something new)
I use 0dB & -3dB
My iris is at F1. 6 most of the time
I use lighting (It still gets grain)
I change my presets around every so often
This is a similar issue for other Xh A1s owners. Someone told me to reset my camera several times but that didn't work either. I tried using lights for all my videos that are filmed inside but there is still grain in the darker areas. I cant rely on lights to do the trick for me because I'm rarely going to film at my house. If you get a chance can you please tell me the main setting that you use for your HDV camera? My best guess is that the my settings are wrong. If you have any idea can you please reply? Thank you!
How are you monitoring? Does the noise show on a direct HDMI connect to a HDTV?
Can you post a sample frame showing the noise?Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Canon HX-A1 verse HX-A1s and buying one
By SkeeterHarris in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 28th Jun 2011, 23:04 -
Canon XH A1s (Grain Problems)
By mseidner24 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 26th Feb 2011, 19:17 -
Canon xh-a1s playback on xh-a1??
By frikandel in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 4th Nov 2010, 17:14 -
Any good guides on the Canon Xh A1s?
By Shamboola in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 1st Apr 2009, 03:13 -
Canon XH-A1 or Canon XH-A1S?
By ProducerHarley in forum Newbie / General discussionsReplies: 5Last Post: 12th Feb 2009, 23:34
