    Aug 2008
    Australia
    I have been trying to convert a full hd clip from its mkv container to mp4 for x box 360 playback. The file inside is in vc-1 format. After the conversion instead of x box 360 complaint mp4 an avc file is produce which neither my computer nor the 360 recognize.
    So i tried using Xvid4psp and sure enough it does produce an mp4 file however its doesnt play on my 360 and always gives a playback error.
    I am still a newb in the conversion arena and Gotsent has always worked for me converting 1080p files however it seems to be an issue now. Any advice? the info for the mkv is provided
  2. VC-1 video is not compatible with an MP4 container, so you'd have to encode. To avoid encoding, I would try using WMVMuxer. It doesn't always work, but it may for you.
    Aug 2008
    Australia
    Thanks. i tried using WMVMuxer but it keeps having issues with registering HDTV file and is unable to open the main program. Any other alternatives?
