Just bought a new Hi-Def Canon Vixia HF-200. Is there a tripod for this camera where I can control the zoom and "On" and "Off" button from the tripod?
No, remote IR is the only option. A problem with my Canon HV20 is an IR blind spot at the rear of the cam. I'm not sure if the HF has the same issue.
Older Sony cams had a hardware Ctl-L interface for tripod zoom controls.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
They make remotes for that camera, you should use that if you cant find what your looking for.
Suggestions for decent tripod for Canon XA10?
By sdsumike619 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 7th Feb 2012, 15:02 -
Tripod for Camcorder
By ayim in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 16th Dec 2009, 10:36 -
Canon GL1 remote control tripod questions
By nopEda in forum Newbie / General discussionsReplies: 2Last Post: 3rd Nov 2008, 12:42 -
Tripod help
By newsphotog in forum Newbie / General discussionsReplies: 17Last Post: 7th Apr 2008, 10:20 -
Looking for a good tripod for my camcorder
By seven_deuce offsuit in forum Off topicReplies: 12Last Post: 16th Oct 2007, 11:19
