  1. Hi, i cannot find anywhere file mpeg2enc.intel, which is required. Can anyone send it to me, or share it? Another problem is that when I try install these 2 files: mencoder and mplayer and there is a field where i have to type the password to my OS. However, I have no password and when im trying to continue with the installation a message pops out that i have to type in the password. Can someone help me?
  2. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    Originally Posted by wlochatyjoe View Post
    Hi, i cannot find anywhere file mpeg2enc.intel.
    The link is on the webpage and in the installer window.
    There's also this zip'ed copy. Unzip before use.
    The installer will use the sudo command in the background, which requires a non-blank password. You may set a user account password in System Preferences > System > Accounts. (This is only needed for installation. Feel free to revert to your old password after a successful installation.)
  3. Thanks dude! Everything worked well. Thanks for help!
