Hey, I've got 4:3 Movie, but want to play it on my Sony Home Theatre with 16:9 format and with subtitles. What should I do to Save this Movie into 16:9 format? I know howto add subtitles but I don't know howto change formatMaybe it's good idea to cut down of the movie, but I don't know...
You haven't given many details of what equipment you're using, but a properly configured player + monitor combination would do all that automatically (i.e. pillarbox the 4:3 video onto a 16:9 screen).
Unless you think you know better than the original director and decide to start cropping the image cause it's not "full screen"
Trev
The only way to do this is to pick a L X W size that is a 16:9 aspect ratio, a size that falls within your current 4:3. Say for example your 4:3 is 704 X 528, then pick size like 688 X 384 for your new size. You want something close to your original size, lengthwise, so you won't have to crop so much.
Set your autosize to 16:9, and make sure you use the CROP feature to decide where, and how much, to trim off from the top and bottom of your final video. That's where the most will come off, but some will come from the left and right side as well.
HOWTO: Edit Motion JPEG (MJPG) in Adobe or even Windows Movie Maker
By rallymax in forum EditingReplies: 53Last Post: 25th Jan 2012, 21:23 -
Save in Old 1.0 avi format
By jliggett in forum Video ConversionReplies: 5Last Post: 29th Mar 2011, 18:31 -
how to save a videoclip in .mov format
By marlo in forum Newbie / General discussionsReplies: 0Last Post: 11th Nov 2010, 01:53 -
Help! How do I save my video in a high definition format
By macleoda in forum Newbie / General discussionsReplies: 3Last Post: 3rd May 2009, 15:50 -
Best format to save AVI files on PC
By bpatters69 in forum Video ConversionReplies: 6Last Post: 31st Mar 2008, 09:31
