I've read a few threads, and the consensus seems to be that if you want a quick capture from Hi8 use a Sony DCR-TRV330 Camcorder.
If you want better quality though I understand I should use a dedicated Sony Hi8 deck like the Sony EV-S7000.
Problem is I'm in the UK and the machines available here like the Sony EV-C2000E don't say much about support for NTSC.
Does anyone have any info on whether the C2000E supports NTSC?
My experience (which was rather extensive) was that the higher end Digi8 camcorders like the TRV820 did a convincingly better job of capturing than the EV-S7000.
I noticed a change of motherboard and card also did a better job of capping than an old setup I had.
If you don't have too many tapes, a lab with a far superior setup would probably be best at achieving "perfect" captures...
Near Perfect subtitles
By Afterlife in forum User guidesReplies: 13Last Post: 27th May 2012, 01:23 -
Getting perfect AR on wide TV?
By terrypin in forum Authoring (DVD)Replies: 7Last Post: 15th Sep 2011, 16:08 -
Sony Hi8 has been defective but want to play the Hi8 tape
By coody in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 16Last Post: 22nd May 2009, 22:06 -
Hi8 vcr, better playback than a Hi8 camcorder?
By Knightmessenger in forum Capturing and VCRReplies: 8Last Post: 22nd Dec 2007, 01:11 -
Will cheap new Hi8 camcorder output better than old, worn Hi8 camcorder?
By ErikL7 in forum RestorationReplies: 7Last Post: 2nd Sep 2007, 06:26
