This probably doesn't fit in any forum but just wanted to pass this on. I have an LG lcd tv and the tv suddenly stopped responding to the remote. My son has a similar tv and the remote worked ok on his tv so we figured it was the infared remote on the front of the tv. After some serching on the net I came across a post and the person had the same issue, had replaced the IR on the tv and still no joy. He then was given this tip to fix it. Put a headphone jack into the 'remote in' hole on the back of the tv and the remote would work (you didn't have to leave it, just put it in and pull it out). I tried it and it worked!
I thought this may have had something to do with cleaning a connection so I used compressed air to clean it out and pushed the jack in and out a couple of times. No issues since.
Am I right in thinking this cleaned a connection or would it have more to do with resetting a connection?
Just wanted to pass this on in case someone else had an issue with remotes.
I'm betting it's a switched jack which disconnects the main remote sensor.
If you have a model number for the TV, maybe I can locate a service manual. -
I tried using a dvd remote from one Apex dvd player on another Apex dvd player and one of the buttons kept changing the region codes among others things.
Sony RDR-HX710: remote not working, how to access recordings?
By disconnekt in forum DVD & Blu-ray RecordersReplies: 10Last Post: 4th Feb 2011, 03:01 -
Any one with a non working cyberhome dvr-1200 or 1600 will buy your remote
By therd3 in forum Newbie / General discussionsReplies: 0Last Post: 21st Sep 2010, 00:21 -
Pioneer DVR video outputs not working - possible to fix? other options?
By JimmyMcV in forum DVD & Blu-ray RecordersReplies: 2Last Post: 10th May 2010, 23:59 -
Windows Media Encoder not working properly in remote desktop
By George2 in forum Newbie / General discussionsReplies: 2Last Post: 24th Jun 2009, 23:14 -
Insignia NS-DRVCR - Tried Hack Got It Working Now My Remote Won't Work
By GTAGamesLvr in forum DVD & Blu-ray RecordersReplies: 7Last Post: 28th Dec 2007, 05:37
