Hey, long time reader here, I've been using this site for over 6 years, it's a great resource.
I capture HD mpg2 .TS files, and occasionally get slight errors on long recordings. The initial error could be as small as lasting less than a second or just one or two frames.
I want to know what software I can use to edit (remove commercials/segments) these files without changing the spots with errors, or without removing any extra audio/video frames from the error spot, etc, IE: no loss or change from the original file.
I've been using VideoReDo for a long time now, which will always remove extra audio or video frames from a given error spot, regardless of the settings chosen for ignoring errors/frames and regardless of how short or small the error is. I don't believe the quickstream fix feature prevents this either from what I remember.
I've noticed in the past that some demux/remux software seems to be able to losslessly remux without any change at all to any error spots, which is what I'm going for. If it'd be possible to fix the error, that'd be good as well, but I doubt it's too realistic so I'm just concerned with keeping it the same as in the original file. In the past I even remuxed a .TS file with a new audio file and the error spot visually stayed the same as it was in the original file, no loss or change, which isn't possible at all with VRD as far as I know.
So I need recommendations of software to use to edit the files and remove segments without any change at all to the error spots or any loss of audio/video frames. Free software if possible would be better, but I'll listen to any recommendations. It would also help if it's easy to use in terms of editing and removing commercials. Thanks a lot in advance.
I had a larger post written with more details, but I tried to cut it down and keep it as simple as I could. Thanks again.
Results 1 to 1 of 1
Lossless DVD ripping/editing on Mac
By nobody_home in forum MacReplies: 5Last Post: 24th Nov 2010, 14:28 -
Help needed: Lossless (fast) DVD -> mpg2 -> DVD, How to?
By dvddummy2 in forum Video ConversionReplies: 2Last Post: 30th Aug 2010, 10:21 -
TV Recording like CTU and DIMENSION and lossless editing
By Strawson in forum Newbie / General discussionsReplies: 3Last Post: 25th Jun 2010, 20:00 -
Editing Picture Resolution on MPG2 and VOB files
By vivivivi in forum Authoring (DVD)Replies: 1Last Post: 9th Apr 2008, 18:16 -
Lossless editing of .m2t (MPEG-2 TS) in Avisynth
By Tigon in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 8th May 2007, 08:23
