Hello, I have problem transcode the DVD to xvideo with quite unusual scenerio
I have the DVD files (Vob) with 3 steam
1. Mpeg2 Video
2. Audio steam mono
3. another Audio stream mono
What I want to do is convert this file to xvideo with stereo audio which have audio stream-2 as left channel and audio stream-3 as right channel.
Is there a program to do this in single step? I have to convert such files more than 100 pieces. So, I am looking for a tools that support batch process. I try to use ffmpeg with no success. Any recommend on command line instruction, programs would be appreciate (WinXP32bit).
You would have to mix the audio separately first, then mux with the video during authoring. What you are asking for is not something that is done as normal practice, and is therefore not something offered by the usual packages. You might be able to script the steps sequentially to obtain the same result, if you know you command line tools well enough.
Read my blog here.
You can do this, but it's not a good idea. Why?
1) Playback devices usually don't offer the ability to only play the left or right channel on Divx/Xvid videos.
2) PCs and many standalone DVD players will play Divx/Xvid with multiple audio tracks and let you change between them.
If you must do this, convert each audio channel separately to WAV format and join them in something like Audacity and then convert that joined WAV file into MP3 or whatever you like. Mux the video with the audio you created using something like VirtualDubMod. I can't help you with command line programs to do it and it may not be possible on the command line. -
Thanks for the reply and comment and yes I must do this. Still open for the suggestion
Convert AND Combine Multiple VCD DAT files to Single Divx/Xvid file
By GrayStrickland in forum Video ConversionReplies: 4Last Post: 17th Aug 2012, 13:23 -
How to combine *.264 video + *.aac audio to one file?
By video-fan in forum Video ConversionReplies: 5Last Post: 18th Oct 2011, 03:38 -
How do I reduce sound channels from 5 to 2 on my xvid file?
By aqueousdan in forum AudioReplies: 6Last Post: 5th Jun 2010, 14:22 -
How to merge/combine and/or convert VOB, BUP, and IFO into one file?
By gordes04 in forum Video ConversionReplies: 3Last Post: 11th Apr 2010, 20:39 -
convert 2 audio track xvid file to ipod 3g
By felix in forum Video ConversionReplies: 1Last Post: 8th Oct 2008, 15:45
