My boyfriend copied a DVD that we owned a while ago, but the original dvd has gotten lost somehow. I would like to copy our copy of the dvd, but I can't figure out how to do it. I have Mac the Ripper and I used that to rip the dvd to my hard drive, but I can't figure out how to copy it properly. Can anyone help me?
Thanks!
Vanessa
Results 1 to 9 of 9
Copy the DVD to your hard disk. (MacTheRipper isn't needed per se, as the copy will not have CSS encryption or other copy protection to defeat.)
Drop the VIDEO_TS folder on the DVD Imager application icon, to create an UDF formatted disk image.
Use Disk Utility to burn the image to a DVD-R disc.Last edited by Case; 9th Feb 2010 at 16:58.
DVD Imager is a simple UI for mkisofs. Ditto for DVD Image Utility (still supported), which just differs in that you drop a folder containing the VIDEO_TS folder on it, or the resulting image itself, if you want to burn it. There's also mkisofsTool, a Java based GUI for the HELIOS version of mkisofs if you want many other nifty capabilities without going to the terminal.
Toast, copy disc.
Create a new disk image (using Disk Utility) of the volume. Save it as a master, no compression nor encryption. Then drop that image file into Disk Utility, click on it (in the list on the left) and click the "Burn" button. Follow the directions.
Use LiquidCD (donationware) http://www.maconnect.ch/
- launch it and select the video icon
- drop your VIDEO_TS folder from finder to its window
- burn it at the slowest speed (for a better compatibility with old home DVD Players)
Your disk will be very compatible (it uses the same format than iDVD / DVDSP / Toast during burning) and you avoid the need to create an intermediate image-disk
byeFor DVD, iPad, HD, connected TV, … iMovie & FCPX? MovieConverter-Studio 3 (01/24/2015) - Handle your camcorder's videos? even in 60p or 60i? do a slow-motion? MovieCam. -
Ahh. Having other apps around, i never knew about the plain Disk Utility method, nor LiquidCD.
Disk Uility only burns an existing disk image and is not able to produce a good DVD-VIDEO image disk (bad compatibility with old players). You need to use a third soft first to make your image disk (the unix tool mkisofs for example, or its mac wrapper DVDImager)
The advantage of LiquidCD is to directly burn a folder to ISO1.02+ISO track, and it uses the Apple framework (the oneuse by Disk Utility) to burn the disc.
I prefer the last one
Problem copying DVDs to hard drive (previously copied from videos)
By avz10 in forum RestorationReplies: 4Last Post: 2nd Mar 2010, 22:54 -
Copying a copied dvd
By Angel87341 in forum Newbie / General discussionsReplies: 1Last Post: 9th Feb 2010, 12:56 -
Can a music CD be copied into a DVD?
By coody in forum AudioReplies: 6Last Post: 13th Oct 2008, 17:32 -
Copying,Copied DVD-Rw disc to,DVD-R disc
By 306james in forum DVD RippingReplies: 3Last Post: 12th Nov 2007, 11:45 -
Copying, Copied DVD-RW DISC TO DVD-R DISC
By 306james in forum FeedbackReplies: 2Last Post: 12th Nov 2007, 04:44
