Hi. Looking for advice on photo to DVD slideshow software. I am trying out Wondeshare DVD slideshow, but I am getting a little frustrated at the results. I have tried 4.3 and 16.9, yet, when burnt to the DVD, the photos have always been slightly stretched. Not been able to work out why this is, so, either looking for the answer OR a better recommendation?
It may be in the settings in the software: it's stretching the photo to fit the screen, you'll need to uncheck that feature, or create your slides with a photo editing software to match the anticipated screen resolution. I have to uncheck the feature in ProShow, as well as other settings; every time I use it - because of the defaults.
;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep" -
Hi, yeah, that's the point. I've ticked 'keep original aspect ratio' and it still seems to be stretching the images. Cant work out why that is, so, if no answer then can anyone recommend me another photo to DVD slideshow app?
Going from high resolution photos to low resolution photos
By bryankendall in forum Newbie / General discussionsReplies: 7Last Post: 5th Jan 2018, 12:57 -
Newbie Question: rapid less than a second cycling of photos, advice?
By ppc1 in forum EditingReplies: 4Last Post: 22nd Apr 2011, 20:08 -
Photos off DVD video made of photos?
By 5chandlers in forum Newbie / General discussionsReplies: 7Last Post: 16th Aug 2009, 13:31 -
Regular DVD's giving me playback issues, Need some advice
By heman31 in forum DVD RippingReplies: 2Last Post: 29th Oct 2008, 20:35 -
Optimisation for photos on DVD
By bananadude in forum Authoring (DVD)Replies: 8Last Post: 14th Jun 2008, 22:11
