    Aug 2005
    Europe
    Is anyone using the Verbatim 3.5'' External Hard Drive eSATA & USB Combo 1TB (Product Number: 47526)? Verbatim does not mention what is the speed and brand of this HDD. Does anyone know?
  2. Member [_chef_]'s Avatar
    Nov 2002
    Germany
    Surely Samsungs........
    *** Now that you have read me, do some other things. ***
    USA
    If you are running Windows and the drive is plugged in, look at your Control Panel>Device Manager as it usually lists the brand and model of connected drives. Not sure how it does with USB drives as I don't have any hooked up at present, but I think they would be listed there also.
    Putting the info from my laptop Device Manager (ST9120822AS) into a internet search engine, it appears to be a Seagate Momentus 5400.3 ST9120822AS 120GB 5400 RPM 8MB Cache 2.5" SATA 1.5Gb/s Notebook Hard Drive.
    Alternatively, try SIW. It gives you a lot of information, including info about drives. http://www.gtopala.com/siw-download.html
    EDIT: From a German review, they say it's a SAMSUNG EcoGreen F2 HD103SI 1TB 5400 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive
    Aug 2005
    Europe
    I was under the impression that the speed of the hard drive in this combo was 7200RPR and not 5400RPR.
