Right now I've been ripping some of my bluray dvds, and I usually just keep the "main" m2ts file. The problem is, though, that when I play a m2ts file that has DTS audio in powerdvd or PVRX2, the audio is missing. I know it's present, though, because mpc-hc plays back the audio fine. As well, when I play the blu-ray as a disc using powerdvd or if I mount an iso of the DVD, the audio plays back fine. Also, I've tried demuxing the m2ts file, and powerdvd plays back audio-only .dts file fine. However, when I remux it, the same problem occurs.
Does anyone know what I need to do so that the dts audio is recognized?
Results 1 to 1 of 1
HD .M2TS with .DTS audio playback
By rajsharma714 in forum Blu-ray RippingReplies: 2Last Post: 8th Oct 2010, 13:00 -
DTS Audio not recognized when I play movies from my extern HDD through PS3!
By Spdngblt56 in forum AudioReplies: 1Last Post: 8th May 2010, 18:51 -
AVCHD M2TS playback problem in PowerDVD
By prizi in forum Software PlayingReplies: 2Last Post: 4th Apr 2009, 08:18 -
Easy way to extract audio (DTS) from a .m2ts stream and convert it to AC3?
By marklight in forum AudioReplies: 1Last Post: 8th Sep 2008, 18:42 -
M2TS & DTS Audio Track
By GeeForce11 in forum Blu-ray RippingReplies: 25Last Post: 14th Jul 2008, 21:31
