Followed instructions, but just registered as data disc like it should... How do you play it. Music doesn't work. Photos doesn't work. Wont allow movie...
Thank you in advance,
Mark Franklyn
Nobody here created that hack. Videohelp.com does not create DVD hacks. People just post them here.
You do realize that the hack listed:
Is for DVD Only.....right?To set DVD (not BLU-RAY!) Region to “0”, download file “6000.zip” (often also called “LG6000.zip”) from here:
http://www.multi-region.net/_media/6000.zip
Save the file and then unzip and extract it to your hard drive.
Now burn the subdirectory RMTM0000 and its contents (not the text file) onto a CD-ROM (ISO format, “closed” CD-ROM).
Insert CD-ROM into the LG BD 300 player, and when the Region Management System screen is displayed, set the Region Code to “0” using your remote. Once done, press “PAUSE” on you remote to save, and you’re done! -
You have to do the following.
1) Download the 6000.zip and unzip it.
2) Burn it to CD-R or CD-RW (CD-R is probably better) in ISO format, disc at once, and no multisession EXACTLY as said above with the entire RMTM0000 directory and its contents. Close it (finalize it).
3) Put the disc in your player. Hope it works.
We can't guarantee that ANY hack will work or that your player won't be damaged by trying them. Some hacks don't work on models sold in the USA and Canada and were only tested on European and/or Asian models. Hardware changes by the manufacturer over time can also break a hack that did work in the past on North American models. Apply any hacks at your own risk. -
Thank you both, but special thanks to jman98.
I had followed those. I have used the codes here, I never used the forum is what I meant to say.
But I did miss the (no-joliet)ISO and I made mine with Power2Go (which says specifically it makes anything but)
Thanx, again...
Mark Franklyn
Sony BDP-s370 hack problem..
By manicjon in forum DVD & Blu-ray PlayersReplies: 1Last Post: 10th Jan 2011, 08:41 -
un-hack a hack?
By hnw in forum DVD & Blu-ray PlayersReplies: 9Last Post: 9th Jan 2011, 10:30 -
Toshiba SD190 hack problem
By elaine1 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 8th Jan 2010, 11:00 -
Denon 1730 hack problem
By kupsjon in forum DVD & Blu-ray PlayersReplies: 1Last Post: 21st Dec 2007, 22:59 -
LG RC299H region code hack problem
By maxa in forum DVD & Blu-ray PlayersReplies: 2Last Post: 20th Sep 2007, 05:37
