Hi experts,
I am looking suggestion with minimum cost
I want to record from Three cameras . Questions are as follows
Yes it is recorded first and later put on broadcast on web. Bassically we are Making videos for web . What setup you suggest with reuse of our sr12e camera.? We want to minimize time to broadcast from Shooting. Any suggestion My friend ?
- How can i use my existing PC or MAC for Video mixing input from three cameras?
- How i can attach three different mics, if the Cam does not have external mic , can i use Podcast studio for external mics and use it for audio and later on attach that with video ?
- I have bought Sony HD SR12E how i can use that camera with the mxing software for live mixing as it does not have Firewire
- Any Cheap option for rest of 2 camera? They can be SD ..
Thanks in advance
BR
Zeeshan
Stockholm
Minimum cost? What is your budget? It's hard to say unless you describe your project more.
You'll need a fast computer - Quad Core with 4GB RAM or better
If you are shooting inside, you must think about lighting.
You should buy 3 of the same camcorders because it will be impossible to color and audio match the video footage during editing if you have different ones.
Get a fluid head tripod for each camcorder. Velbon is OK
http://www.bhphotovideo.com/c/product/366741-REG/Velbon_DV7000_DV_7000_Tripod_with_2_Way.html
If you use an external mic for each camera, it should be the same model of microphone. Again, you won't be able to match the sound otherwise.Or, use 1 high quality external recorder like the Zoom H4N.
http://www.bhphotovideo.com/c/search?Ntt=Zoom+H4N&N=0&InitialSearch=yes
Software
Vegas Pro
Pluraleyes Plugin http://www.singularsoftware.com/pluraleyes.htmlLast edited by Soopafresh; 9th Feb 2010 at 18:35.
"Quality is cool, but don't forget... Content is King!"
Video cameras stop recording
By Coolboy55 in forum Capturing and VCRReplies: 5Last Post: 7th Nov 2008, 13:07 -
Suggestion on Laptops for sound recording purposes (vocals, keyboard o/p)
By tsrusa2002 in forum AudioReplies: 4Last Post: 18th Mar 2008, 22:27 -
Anyone try the Aiptek HD cameras?
By Forum Troll in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 29th Dec 2007, 17:39 -
I need suggestion recording cell phone voice message
By videocheez in forum AudioReplies: 2Last Post: 7th Sep 2007, 16:55 -
cameras!!
By dewolf in forum Off topicReplies: 31Last Post: 11th Aug 2007, 21:02
