  1. What does Illegal Decimal Floating Point Calculation Order Mean ? And my second question is that I have an avi file and I haev the Nimo pack codec and I can't play the AVI file first I thought the file is not complete so I tried to DivFix it but when I tried to open the file it said that is not an avi what should I do ?!?!
  2. Chances are that if it aint an avi, its either dead, or its a mpg. Try renaming it and opening it with somthing else that uses mpgs. There is a prog like DivXFix called MPEG-Corrector.exe.
  3. No it has to be an avi because its a movie and a dvd quality movie in mpeg has to be over 1 gig this file is only 700mb it is an avi
  4. Do some reading. Uncompressed AVI files are MUCH larger than mpg, you are almost certainly looking at a DivX file, or perhaps an AVI using MJPEG or some other lossy compression method.
  5. I know I've seen umcompressed avi fiels those are over a gig but mine is 700 mb so its compress I don't know what to do! I want to watch my movie ahhhhhh
