Alright, I have a very simple question. I have 3 seasons of a tv show on my hard drive that i would like to put on DVD, the files are in .avi format, now conversion is not a problem, i was going to acquire "Xilisoft AVI to DVD Converter" to convert them to a format usable in a DVD player. My Issue is how to put how ever many will fit on disc but being able to 1. make them continuously play one after another. or 2. make them each a chapter so i can just skip to the next one. All help is greatly appreciated.
Governments should be afraid of the people, not the other way around
I wouldn't bother 'acquiring' Xilisoft. There are several free converters that will do a far better job that Xilisoft, which is, IMO, rubbish at any price.
The only payware product I believe is worth consideration is ConvertXtoDVD.
Of the free alternatives, I like and use AVStoDVD, which is maintained regularly and well supported here by it's author. It uses the excellent HCEnc encoder and does a very good job. After that you might consider DVD Flick, or learning how to do the encoding and authoring manually.
As for how much can fit on a disc - that is up to you. You can put up to 7+ hours on a single layer DVD, if you are happy with low quality. Normally, 2 hours is about the limit for reasonable quality, however because most downloaded material is already quality compromised, you can stretch it to a bit longer. If these are standard 42 - 50 minute episodes, then 3 to a disc is reasonable. More than that will affect encoding quality.
The rest of your question is simply to do with how you author the disc. Each tool has different options, but most support playing from one title to the next.
Personally, I long ago decided that the best option was a player that could play the avi files. No conversion, no quality loss. And I could fit a whole lot more on a disc.Read my blog here.
ill try the avstodvd and as for the player it would most likely be played on a ps2 or xbox 360 or the dvd player in my car "jensen 9412" the quality of the shows is actually very good considering that i downloaded them
Avi files "Not Support Video" on dvd player?
By aelfheah in forum DVD RippingReplies: 11Last Post: 12th Sep 2011, 12:18 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 01:27 -
do my AVI files need to be "pre-processed" before creating DVD?
By EtherJones in forum Video ConversionReplies: 3Last Post: 11th Jun 2010, 00:46 -
"stretching" or "cramming" aspect ratio when I convert .avi to MP4
By Agent Bauer in forum ffmpegX general discussionReplies: 3Last Post: 21st Mar 2010, 10:30 -
Why do I have 2 files? "Movie Clip" and "M2V File"
By tygger in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jun 2007, 21:55
