Calling all MP4Box experts!
Ok, so I'm attempting to join track #1 (video) from an MP4 file along with an AC3 file using the following syntax:
MP4Box.exe -add "c:\temp\file.mp4#1" -add file.ac3 outputfile.mp4
Note that this is the exact syntax that Yamb gave me in the log.
This is what I get on the output:
IsoMedia import - track ID 1 - Video (size 720 x 400)
Unknown input file type
Saving to c:\temp\outputfile.mp4: 0.500 secs Interleaving
The resulting file is then corrupt. Thing is if I use Yamb to do exactly the same thing it works fine, which I don't understand since Yamb is giving me the same MP4Box command syntax in the log!
Any ideas?
Cheers.
I've the same problem with a little difference:
I've an mp4 video file without any audio tracks and i want to put once. I try do do:
Anyone can help me ?Code:C:\Programmi\YAMB>MP4Box.exe -add "C:\Mp4\audio.ac3" "C:\Mp4\Out.mp4" Unknown input file type (Feature Not Supported) Error importing C:\Mp4\audio.ac3: Feature Not Supported C:\Programmi\YAMB>
Have you tried latest mp4box ? https://www.videohelp.com/download/MP4Box-0.4.6-rev2735.zip
ac3 was not supported in older versions. -
you should convert AC3 File to AAC, can do with ac3to and nero aac codec, when you convert ac3 file to aac mp4box work.!!!
MP4Box command to batch MUX MP4s
By jd185051 in forum Newbie / General discussionsReplies: 5Last Post: 2nd Apr 2017, 10:43 -
Command-line command for fixing AVI?
By timur in forum ffmpegX general discussionReplies: 1Last Post: 23rd Sep 2009, 02:23 -
Command line syntax for mp4box?
By freebird73717 in forum Newbie / General discussionsReplies: 4Last Post: 25th Jul 2008, 21:57 -
command line
By exekutive in forum ffmpegX general discussionReplies: 22Last Post: 1st Jun 2008, 23:44 -
H264 + AC3 + AC3 --> VOB - What is wrong with my command line?
By olik in forum ffmpegX general discussionReplies: 5Last Post: 3rd Feb 2008, 07:06
Now run fine ... thanks a lot !
