Closed Thread
  1. Hi all
    I had soem great help getting my Music Video Vcds converted from dat to mpeg I have now ran into a problem with a few
    When ripping the dat files in to mpeg some of the files got split and won't play,ONe will play but it seems like it get's cut off at the end ...however the second part won't play .
    I tried merging with a tmpgenc won't even load and with mpegstreamclip it werges and then the file won't play
    This is what I get from windows media player
    Windows Media Player cannot play the file. The Player might not support the file type or might not support the codec that was used to compress the file.
    Any suggestions ...is tehre a different methpd of ripping these to my hard drive that may work or some other way to merge these files
    Ed
    We were all NEWBIES once and the only stupid question is the one that's not asked?
    One similar topic is enough. Just reply to add new information. Continue in https://forum.videohelp.com/threads/316173-Music-video-vcd
