Hi everybody. I have a strange problem. Although I am able to play mkv files with avc video files inside using WMP12 in Windows 7, there a couple of files that although they play perfectly with vlc or divx player, with wmp I only get the audio.
Any suggestions (apart from using some other player since I use media center connected to my tv)?
Thanks in advance
Windows 7 can't decode all formats so you need an external decoder, I would try ffdshow. You may also need to use Preferred Filter Tweaker to disable the windows 7 internal decoder so ffdshow is actually used. And If ffdshow cause problem you can easily uninstall it. Try avoid codec packs.
How to convert a AAC audio file in a mkv file to AC3?
By wolvie77 in forum AudioReplies: 4Last Post: 13th Mar 2012, 21:59 -
issues to play ac3 audio with WMP12 in windows7 64bit
By deejay.2001 in forum ComputerReplies: 0Last Post: 24th Jul 2011, 19:45 -
Improving the conversion of a .mkv file (DTS) to a .mkv file (AC3). Ideas?
By mdelisle1 in forum Video ConversionReplies: 11Last Post: 19th Jan 2011, 10:50 -
No Audio On AVCHD-DVD, How To Remove Other Audio Tracks From MKV File First
By elistian in forum Video ConversionReplies: 1Last Post: 14th Dec 2009, 06:03 -
avi on wmp12
By shredcaster in forum Software PlayingReplies: 6Last Post: 27th Jun 2009, 08:58
