Hello.
I have an FLV file that I am comparing against another "known good" file. The only difference I can see in the makeup of the file is visible in MediaInfo. My question is what are the "tc" values - and how can I remove them - as they seem to be the only difference between a good video and this one that is causing me some potential errors. The timescale seems way out on the tc as the file is only 3 minutes long. I have not been able to find much info on the web, as it isn't strictly "metadata"
General
Complete name : C:\tmp\test-video.flv
Format : Flash Video
File size : 15.6 MiB
Duration : 3mn 0s
Overall bit rate : 729 Kbps
tc : 10:00:00:00 / 10:00:00:01 / 10:00:00:02 / 10:00:00:03 / 10:00:00:04 / 10:00:00:05 / 10:00:00:06 / 10:00:00:07 / 10:00:00:08 / 10:00:00:09 / 10:00:00:10 / 10:00:00:11 / 10:00:00:12 / 10:00:00:13 / 10:00:00:14 / 10:00:00:15 / 10:00:00:16 / 10:00:00:17 / 10:00:00:18 / 10:00:00:19 / 10:00:00:20 / 10:00:00:21 / 10:00:00:22 / 10:00:00:23 / 10:00:00:24 / 10:00:01:00 / 10:00:01:01 / 10:00:01:02 / 10:00:01:03 / 10:00:01:04 / 10:00:01:05 / 10:00:01:06 / 10:00:01:07 / 10:00:01:08 / 10:00:01:09 / 10:00:01:10 / 10:00:01:11 / 10:00:01:12 / 10:00:01:13 / 10:03:00:00
Video
Format : VP6
Duration : 3mn 0s
Bit rate : 464 Kbps
Width : 640 pixels
Height : 360 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 fps
Bits/(Pixel*Frame) : 0.081
Stream size : 9.96 MiB (64%)
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Duration : 3mn 0s
Bit rate mode : Constant
Bit rate : 64.0 Kbps
Channel(s) : 1 channel
Sampling rate : 44.1 KHz
Stream size : 1.37 MiB (9%)
Thank you in advance
NetStream error: ReferenceError: Error #1069 12:47:09 unknown ERROR MEDIA
when playing that FLV back via a flash player. I do not get that error with a similar FLV file that does not have the TC property. Hence I am wondering what that property is - and how I can possibly remove it (to test if the error still occurs). -
You could try to re-wrap with ffmpeg
ffmpeg -i input.flv -vcodec copy -acodec copy output.flv
or try avidemux to copy the streams
or use flv extract, then reassemble without timecodes or keep it in avi container (if you aren't streaming)
what "flash player" are you using? have you tried another? -
Thank you - using ffmpeg has done the trick and removed the timecodes without changing the quality (the flv extract tool brought out a lot of artifacts).
MediaInfo : what does this figure mean?
By Bonie81 in forum Newbie / General discussionsReplies: 1Last Post: 28th Jan 2011, 22:22 -
[MediaInfo] What exactly is bitrate ?
By Klagar in forum Video ConversionReplies: 2Last Post: 3rd Nov 2010, 09:54 -
MediaInfo question
By Startropic1 in forum Newbie / General discussionsReplies: 7Last Post: 26th May 2010, 11:43 -
MKV and mediainfo
By stiltman in forum DVD RippingReplies: 6Last Post: 14th Sep 2009, 22:36 -
GSpot and Mediainfo Help
By swampwizard in forum Newbie / General discussionsReplies: 4Last Post: 19th Sep 2008, 08:03
