Basic question I know but I'm using a very slow laptop. (specs below) I'm editing HD video and have an external 500 gig HD. My pc has only around 54 gig left on the HD. Both are 5400 rpm, would it be better to transfer all my raw video files to the external HD and work from that? (when I'm editing?)
I'm using PowerDirector 8 and as you can imagine working with this HD video is slow going with the computer I have. Any advice you have is appreciated!
Jason
Here are computer specs:
Sony PCG-7Z2L Laptop
Windows Vista Home Premium
2 gig ram
Intel Pentium Dual CPU T2310 1.46 GHZ
32 bit OS
104 gig HD, 5400 rpm (54 gig remaining)
500 gig external HD 5400 rpm (450 gig remaining)
Theoretically i'd say the internal drive will be faster assuming it's a Sata drive and with a Sata bus (mine is a IDE/ Raid bus only) but as you're working with large files it will slow down your computer a lot imo so probably your external hd is the best solution here.
*** DIGITIZING VHS / ANALOG VIDEOS SINCE 2001**** GEAR: JVC HR-S7700MS, TOSHIBA V733EF AND MORE -
Thanks for the quick response. I need to research a learn a lot more as I'm not familiar with a Sata drive/raid etc. My computer crashes quite a bit working with this HD video and I'm simply looking for ways to minimize this.
Question with My Editstudio 6 Project
By jbitakis in forum EditingReplies: 11Last Post: 6th Jan 2013, 12:43 -
Can I edit HiDef files in same project as StandardDef files?
By cspaul1234 in forum Newbie / General discussionsReplies: 0Last Post: 10th Jul 2011, 20:39 -
Dark City Project-Edit AC3 soundtrack
By apostrophe in forum EditingReplies: 8Last Post: 24th Apr 2010, 00:06 -
Edit a HD project in Adobe Premiere pro 2?
By rajaa in forum EditingReplies: 12Last Post: 22nd Apr 2009, 00:16 -
I am almost done with my first edit project!
By jbigfoot in forum Newbie / General discussionsReplies: 0Last Post: 13th Apr 2008, 06:59
