Closed Thread
Results 1 to 30 of 30
    Dec 2006
    I have been burning, converting, etc for years... I have used 700mb, 4.5gb, etc.. I have been downloading a lot of 720p and 1080p movies in mkv format recently and need to burn them to disc for storage. I don't plan to play them in any stand alone dvd player, just use the disc for storage. I have my pc connected to my hdtv, so I should be able to to burn the mkv's and watch them later via my pc.
    I bought a pack of Memorex DVD+R DL 8x 8.5gb 240min Discs. I tried to burn the normal storage way (cd or dvd iso joliet) in Nero but it said I had to burn as UDF, so I did. Out of 3 tries, one disc didn't have any write failures and it finalized. My Vista laptop can "see" the mkv file sitting on the disc but not actually open it (freezes vlc) or copy it to my desktop (can not read from source file or disc). The XP laptop (which is the one i have connected to my HDTV and the one I would want to watch the mkv's from) won't even recognize the disc, it just spins and spins.. I have never had any problems with burning or reading cd's on these drives.
    Is there a better way to burn? Should I be following other steps in Nero for these double layer discs? Should I use isobuster to convert the mkv to an iso file before burning? I've made a few coasters already and this media isn't cheap... I need a solution. My HD is so full and I need to burn off a few hundred gb's of mkv's and avi's... help!! thx!
    A signature is a block of text that can be added to posts you make.
    In windows XP you need UDF Reader.
    Dec 2006
    Hi, I downloaded the file and followed the instructions.. Right click on "thdudf.inf" and choose Install, but it says Install Error - 'The INF file you selected does not support this method of installation'.
    I tried installing the Adaptec UDF Reader Driver a few days ago but nothing happened.
    What about for the Vista machine?
    May 2007
    Romania
    The problem come from poor quality of Memorex DL discs. Use Verbatim DL. Vista has UDF reader and recognize the disc but can read the file.
  5. I'm a MEGA Super Moderator Baldrick's Avatar
    Did you extract ALL files to a folder and then right click and choosed installed?
    Dec 2006
    Yes. I've installed many many programs in my day.
    Could the disc really be to blame? Is THIS what you're talking about?
  7. Member turk690's Avatar
    Jul 2003
    ON, Canada
    In another thread, I replied I've found that when recorded DL discs do not play or show corrupt data despite having been given valid OK status on that program that recorded it, it usually means the DVD-rewriter involved is on its last legs and has to be replaced. I should have added that such writer will still record successfully to single-layer media but makes corrupt double-layer recordings. There is a fine balance to be straddled here: media and writer. Of the former, of course, use the best you can get (Verbatim?); of the latter, DVD-rewritable drives really only live for about a year maximum reliably. At only US$20 a piece or so nowadays, it shouldn't be too hard to decide to replace a suspect one.
    For the nth time, with the possible exception of certain Intel processors, I don't have/ever owned anything whose name starts with "i".
    Dec 2006
    oh wait wait.. I just realized, BOTH my laptops are Vista. I have a work/home and i just replaced the home with a new vista recently.. so both should read the UDF no problems.?? It just spins in one, and I'm using ISO buster right now to try to extract the mkv file on the other pc.
    Is there a better way to store the large mkv's? Surely an external hd isn't the way to go?
    Dec 2006
    well I used ImgBurn to verify and the discs are bad after I burn them... so its the disc's??
  10. Originally Posted by aerogurl View Post
    You can get an external drive for the cost of a new burner + blank DL media and not spend time burning discs.
    You also won't have to shuffle through discs when you want to access a file.
  11. Member wulf109's Avatar
    Jul 2002
    Try to burn a DL disk with ImageBurn. Go into options and set it at ISO9660+Joliet. If it gives a warning about no layer-break that may be your problem.
    May 2007
    Romania
    Dec 2006
    ordered some Verbatim's, made in Singapore.. hope they work thx guys
  14. Video Restorer lordsmurf's Avatar
    Waste of time. Those tests give many false results.
    Dec 2006
    so I got the Verbatim discs today... first disc, write fail. WHAT IS THE PROBLEM. I have no problems burning anything 4.5gb or 700mb or whatever, nothing is wrong with my drive... what the hell??
  16. My guess is it's your writer.
    Try burning a 8GB or smaller file, if it still fails then it definately is the writer.
    Just for kicks post the log from ImgBurn.
    Dec 2006
    I didn't save the log. I tried burning with both Nero and ImgBurn, both failed.
    "Try burning a 8GB or smaller file" Do you mean on the new disc's? The writer has had no probs burning anything until now. It still works to burn the 4.5gb discs.
    I'm transferring a big MKV file over to my other laptop that has a dvd writer and gonna try it there.
  18. Ok if both Nero and ImgBurn failed then either the file is too big( >8.5GB ) or the writer is failing, Lite-On's and laptop writers are notoriously bad for DL.
    Without a burn log we are just guessing here.
    Feb 2004
    Pleasant Hill, CA
    Imgburn automatically saves the log - "Help" menu -> "Imgburn Logs".
    Dec 2006
    great, thanks.. here it is.
    ; ImgBurn Version 2.5.0.0 - Log
    ; Friday, 12 February 2010, 14:20:38
    I 13:50:56 ImgBurn Version 2.5.0.0 started!
    I 13:50:56 Microsoft Windows Vista Home Premium Edition (6.0, Build 6001 : Service Pack 1)
    I 13:50:56 Total Physical Memory: 3,106,440 KB - Available: 1,030,024 KB
    W 13:50:56 SPTD can have a detrimental effect on drive performance.
    I 13:50:56 Initialising SPTI...
    I 13:50:56 Searching for SCSI / ATAPI devices...
    I 13:50:57 Found 1 DVD-ROM and 1 DVD±RW/RAM!
    I 13:52:07 Operation Started!
    I 13:52:07 Building Image Tree...
    I 13:52:07 Calculating Totals...
    I 13:52:07 Preparing Image...
    I 13:52:07 Contents: 1 File, 0 Folders
    I 13:52:07 Content Type: Data
    I 13:52:07 Data Type: MODE1/2048
    I 13:52:07 File System(s): UDF (1.02)
    I 13:52:07 Volume Label: [Not Configured]
    I 13:52:07 Size: 8,533,764,419 bytes
    I 13:52:07 Sectors: 4,166,878
    I 13:52:07 Image Size: 8,534,327,296 bytes
    I 13:52:07 Image Sectors: 4,167,152
    I 13:52:07 Operation Successfully Completed! - Duration: 00:00:00
    I 13:52:12 Operation Started!
    I 13:52:12 Building Image Tree...
    I 13:52:41 Calculating Totals...
    I 13:52:41 Preparing Image...
    I 13:52:41 Contents: 1 File, 0 Folders
    I 13:52:41 Content Type: Data
    I 13:52:41 Data Type: MODE1/2048
    I 13:52:41 File System(s): UDF (1.02)
    I 13:52:41 Volume Label: Tropic Thunder 1080p
    I 13:52:41 Size: 8,533,764,419 bytes
    I 13:52:41 Sectors: 4,166,878
    I 13:52:41 Image Size: 8,534,327,296 bytes
    I 13:52:41 Image Sectors: 4,167,152
    I 13:52:53 Operation Successfully Completed! - Duration: 00:00:40
    I 13:52:53 Operation Started!
    I 13:52:53 Source File: -==/\/[BUILD IMAGE]\/\==-
    I 13:52:53 Source File Sectors: 4,167,152 (MODE1/2048)
    I 13:52:53 Source File Size: 8,534,327,296 bytes
    I 13:52:53 Source File Volume Identifier: Tropic Thunder 1080p
    I 13:52:53 Source File Application Identifier: ImgBurn v2.5.0.0
    I 13:52:53 Source File Implementation Identifier: ImgBurn
    I 13:52:53 Source File File System(s): UDF (1.02)
    I 13:52:53 Destination Device: [0:1:0] Optiarc DVD+-RW AD-7580S FD04 (F (ATAPI)
    I 13:52:53 Destination Media Type: DVD+R DL (Disc ID: MKM-001-00) (Speeds: 2.4x)
    I 13:52:53 Destination Media Sectors: 4,173,824
    I 13:52:53 Write Mode: DVD
    I 13:52:53 Write Type: DAO
    I 13:52:53 Write Speed: MAX
    I 13:52:53 Link Size: Auto
    I 13:52:53 Lock Volume: Yes
    I 13:52:53 Test Mode: No
    I 13:52:53 OPC: No
    I 13:52:53 BURN-Proof: Enabled
    I 13:52:56 Book Type Setting: N/A
    I 13:52:56 Optimal L0 Data Zone Capacity: 2,083,584
    I 13:52:56 Optimal L0 Data Zone Method: ECC Block Boundary
    I 13:52:56 Set L0 Data Zone Capacity Succeeded!
    I 13:52:56 Filling Buffer... (40 MB)
    I 13:52:57 Writing LeadIn...
    I 13:53:56 Writing Session 1 of 1... (1 Track, LBA: 0 - 4167151)
    I 13:53:56 Writing Track 1 of 1... (MODE1/2048, LBA: 0 - 4167151)
    I 13:53:56 Writing Layer 0... (LBA: 0 - 2083583)
    I 14:15:50 Writing Layer 1... (LBA: 2083584 - 4167151)
    W 14:15:53 Failed to Write Sectors 2084256 - 2084287 - Reason: Write Error
    W 14:15:53 Retrying (1 of 20)...
    W 14:15:53 Retry Failed - Reason: Invalid Address For Write
    W 14:15:53 Retrying (2 of 20)...
    W 14:15:53 Retrying (3 of 20)...
    W 14:15:53 Retrying (4 of 20)...
    W 14:15:53 Retrying (5 of 20)...
    W 14:15:53 Retrying (6 of 20)...
    W 14:15:53 Retrying (7 of 20)...
    W 14:15:53 Retrying (8 of 20)...
    W 14:15:53 Retrying (9 of 20)...
    W 14:15:53 Retrying (10 of 20)...
    W 14:15:53 Retrying (11 of 20)...
    W 14:15:53 Retrying (12 of 20)...
    W 14:15:53 Retrying (13 of 20)...
    W 14:15:53 Retrying (14 of 20)...
    W 14:15:53 Retrying (15 of 20)...
    W 14:15:53 Retrying (16 of 20)...
    W 14:15:53 Retrying (17 of 20)...
    W 14:15:53 Retrying (18 of 20)...
    W 14:15:53 Retrying (19 of 20)...
    W 14:15:53 Retrying (20 of 20)...
    W 14:16:00 Retrying (21)...
    W 14:16:00 Retry Failed - Reason: Invalid Address For Write
    W 14:16:01 Retrying (22)...
    W 14:16:01 Retry Failed - Reason: Invalid Address For Write
    W 14:16:02 Retrying (23)...
    W 14:16:02 Retry Failed - Reason: Invalid Address For Write
    W 14:16:02 Retrying (24)...
    W 14:16:02 Retrying (25)...
    W 14:16:03 Retrying (26)...
    W 14:16:03 Retry Failed - Reason: Invalid Address For Write
    W 14:16:03 Retrying (27)...
    W 14:16:03 Retrying (28)...
    W 14:16:03 Retrying (29)...
    W 14:16:03 Retrying (30)...
    W 14:16:04 Retry Failed - Reason: Invalid Address For Write
    W 14:16:04 Retrying (31)...
    W 14:16:04 Retrying (32)...
    W 14:16:04 Retrying (33)...
    W 14:16:05 Retrying (34)...
    W 14:16:05 Retry Failed - Reason: Invalid Address For Write
    W 14:16:05 Retrying (35)...
    W 14:16:05 Retrying (36)...
    W 14:16:05 Retrying (37)...
    W 14:16:05 Retrying (38)...
    W 14:16:06 Retrying (39)...
    W 14:16:06 Retry Failed - Reason: Invalid Address For Write
    W 14:16:06 Retrying (40)...
    W 14:16:06 Retrying (41)...
    E 14:16:07 Failed to Write Sectors 2084256 - 2084287 - Reason: Write Error
    E 14:16:07 Next Writable Address: 2083624
    I 14:16:08 Synchronising Cache...
    I 14:16:17 Closing Track...
    I 14:16:18 Finalising Disc...
    W 14:16:37 Potential 'WaitImmediateIO' Deferred Error - (94%, 0/3) - Session Fixation Error Writing Lead Out
    W 14:16:37 Finalise Disc Failed! - Reason: Session Fixation Error Writing Lead Out
    W 14:16:37 Retrying (1 of 3)...
    W 14:16:55 Potential 'WaitImmediateIO' Deferred Error - (94%, 0/3) - Session Fixation Error Writing Lead Out
    W 14:16:55 Retry Failed - Reason: Session Fixation Error Writing Lead Out
    W 14:16:55 Retrying (2 of 3)...
    W 14:17:14 Potential 'WaitImmediateIO' Deferred Error - (94%, 0/3) - Session Fixation Error Writing Lead Out
    W 14:17:14 Retry Failed - Reason: Session Fixation Error Writing Lead Out
    W 14:17:14 Retrying (3 of 3)...
    W 14:17:28 Potential 'WaitImmediateIO' Deferred Error - (49%, 0/3) - Session Fixation Error Writing Lead In
    W 14:17:28 Retry Failed - Reason: Session Fixation Error Writing Lead In
    E 14:20:11 Finalise Disc Failed! - Reason: Session Fixation Error Writing Lead Out
    I 14:20:11 Finalising Disc (Last Attempt!)...
    E 14:20:34 Finalise Disc Failed! - Reason: Session Fixation Error Writing Lead Out
    E 14:20:34 Failed to Write Image!
    I 14:20:34 Exporting Graph Data...
    I 14:20:34 Graph Data File: C:\\ImgBurn\Graph Data Files\Optiarc_DVD+-RW_AD-7580S_FD04_FRIDAY-FEBRUARY-12-2010_1-52_PM_MKM-001-00_MAX.ibg
    I 14:20:34 Export Successfully Completed!
    E 14:20:34 Operation Failed! - Duration: 00:27:40
    I 14:20:34 Average Write Rate: 3,131 KB/s (2.3x) - Maximum Write Rate: 3,378 KB/s (2.4x)
    I 14:20:37 Close Request Acknowledged
    I 14:20:37 Closing Down...
    I 14:20:37 Shutting down SPTI...
    I 14:20:38 ImgBurn closed!
    Dec 2006
    just tried to burn it on my other laptop, error. said i/o device error or something... here's the log. so I've tried two different types of media and two different burners. wtf?
    I 17:41:51 Operation Started!
    I 17:41:51 Building Image Tree...
    I 17:42:06 Calculating Totals...
    I 17:42:06 Preparing Image...
    I 17:42:06 Contents: 1 File, 0 Folders
    I 17:42:06 Content Type: Data
    I 17:42:06 Data Type: MODE1/2048
    I 17:42:06 File System(s): UDF (1.02)
    I 17:42:06 Volume Label: Tropic Thunder 1080p
    I 17:42:06 Size: 8,533,764,419 bytes
    I 17:42:06 Sectors: 4,166,878
    I 17:42:06 Image Size: 8,534,327,296 bytes
    I 17:42:06 Image Sectors: 4,167,152
    I 17:42:09 Operation Successfully Completed! - Duration: 00:00:18
    I 17:42:09 Operation Started!
    I 17:42:09 Source File: -==/\/[BUILD IMAGE]\/\==-
    I 17:42:09 Source File Sectors: 4,167,152 (MODE1/2048)
    I 17:42:09 Source File Size: 8,534,327,296 bytes
    I 17:42:09 Source File Volume Identifier: Tropic Thunder 1080p
    I 17:42:09 Source File Application Identifier: ImgBurn v2.5.0.0
    I 17:42:09 Source File Implementation Identifier: ImgBurn
    I 17:42:09 Source File File System(s): UDF (1.02)
    I 17:42:09 Destination Device: [1:0:0] TSSTcorp DVD+-RW TS-L632H D400 (E (ATA)
    I 17:42:09 Destination Media Type: DVD+R DL (Disc ID: MKM-001-00) (Speeds: 2.4x)
    I 17:42:09 Destination Media Sectors: 4,173,824
    I 17:42:09 Write Mode: DVD
    I 17:42:09 Write Type: DAO
    I 17:42:09 Write Speed: MAX
    I 17:42:09 Link Size: Auto
    I 17:42:09 Lock Volume: Yes
    I 17:42:09 Test Mode: No
    I 17:42:09 OPC: No
    I 17:42:09 BURN-Proof: Enabled
    I 17:42:12 Book Type Setting: N/A
    I 17:42:12 Optimal L0 Data Zone Capacity: 2,083,584
    I 17:42:12 Optimal L0 Data Zone Method: ECC Block Boundary
    I 17:42:56 Set L0 Data Zone Capacity Succeeded!
    I 17:42:57 Filling Buffer... (40 MB)
    I 17:43:02 Writing LeadIn...
    I 17:43:04 Writing Session 1 of 1... (1 Track, LBA: 0 - 4167151)
    I 17:43:04 Writing Track 1 of 1... (MODE1/2048, LBA: 0 - 4167151)
    I 17:43:04 Writing Layer 0... (LBA: 0 - 2083583)
    E 18:04:37 Failed to read file: 'C:\Tropic.Thunder.UNRATED.PROPER.1080p.BluRay.x26 4-Japhson.mkv'
    E 18:04:37 Reason: The request could not be performed because of an I/O device error.
    I 18:04:37 Synchronising Cache...
    W 18:04:45 User opted to skip the 'Close Track/Session/Disc' functions.
    E 18:04:45 Failed to Write Image!
    I 18:04:45 Exporting Graph Data...
    I 18:04:45 Graph Data File: C:\ImgBurn\Graph Data Files\TSSTcorp_DVD+-RW_TS-L632H_D400_FRIDAY-FEBRUARY-12-2010_5-42_PM_MKM-001-00_MAX.ibg
    I 18:04:45 Export Successfully Completed!
    E 18:04:45 Operation Failed! - Duration: 00:22:36
    I 18:04:45 Average Write Rate: 1,489 KB/s (1.1x) - Maximum Write Rate: 3,367 KB/s (2.4x)
  22. Banned
    Freedonia
    Stop burning at the maximum speed and try a DL burn at 2.4x. Many many weird problems reported here with burns that fail with good media have been solved by burning at lower speeds. I would not rule out that your burner is going bad, but definitely try one burn at lower speed and see if that fixes the problem.
  23. Member
    Dec 2006
    I'm writing at 2.4 in Nero.
  24. Member wulf109's Avatar
    Jul 2002
    Imageburn will compensate for wrong speed selection,.i.e.,if you select 4.0 it will change to 2.4 automatically. I would never use NERO for DL burning and I'm not a NERO hater.
  25. Member [_chef_]'s Avatar
    Nov 2002
    Germany
    Start using legal downloads.
    Your posts indicating opposite so far.
    *** Now that you have read me, do some other things. ***
  26. Member [_chef_]'s Avatar
    Nov 2002
    Germany
    THIEF!!!
  27. Member
    Dec 2006
    yea yea.. like 95% of this website ain't.
  28. Banned
    Freedonia
    Yet your log says you're burning at MAX. MAX is not 2.4.
  29. Maybe your writers don't like Tropic Thunder, I know I didn't.
  30. Mod Neophyte redwudz's Avatar
    USA
    Asking about downloaded, copyrighted material is in violation of our rules. Please read our rules before posting.
    Moderator redwudz
