I have some AVI files that I want to convert to mp4 or mov so that I can play them with Quicktime. They work in VLC fine already. This program works great for me sometimes. The problem is when I have a video that is widescreen. Not sure why it changes the sizes of the conversion. I've tried so many options and even type it in manually but it still seems to decide on it's own to squeeze it... I currently have one at 720x344. What options do I need to choose? Thx!
I would use AVI Demux (Mac version available). You may find you can just repackage without transcoding/re-encoding. AVI Demux should also transfer any AR flags that er in play, although QT may not respect them. If that is the case you may have to resize to 1:1 PAR, then re-encode.
Read my blog here.
I've tried that and the video is choppy, however the audio played perfect since I chose aac.. Thanks for your help on this..
Encode video with different luminance resolution and video resolution
By kylix999 in forum Video ConversionReplies: 14Last Post: 6th Jun 2012, 07:57 -
Auto adjusting screen resolution to video resolution
By Computer Nerd Kev in forum Software PlayingReplies: 11Last Post: 11th Jul 2011, 06:36 -
viewing a QVGA/VGA resolution video with NTSC DV resolution (with a TV)
By Lightbreaker in forum EditingReplies: 1Last Post: 6th Jan 2009, 01:57 -
home video to dvd: resolution issues
By hickmanbetty in forum Newbie / General discussionsReplies: 2Last Post: 6th Jun 2008, 11:56 -
Audio Sync Issues - Can't find resolution!
By cl0nd0n in forum ffmpegX general discussionReplies: 4Last Post: 24th Oct 2007, 21:40
