I'm not familiar with this program and want to convert a .dv file to an .avi.
Of course quality is very important.
What "compression" choice would yield the best result?
Also, which boxes should I select/check off out of these options?
a) deinterlace video
b) interlaced scaling
c) better downscaling
d) frame blending
I ask because I haven't a clue what either of the above means or how they will affect the .avi file one way or the other!
Sorry, however I need your help & suggestions based on you personal experience in order to succeed.
Thanks all
Results 1 to 1 of 1
MPEG Streamclip MPEG-TS to MPEG4/H264 (file size & aspect ratio query)
By Heathy65 in forum Video ConversionReplies: 5Last Post: 4th Apr 2012, 11:31 -
MPEG Streamclip aspect conversion actually crops the image!
By Chamelet in forum Video ConversionReplies: 1Last Post: 4th Apr 2012, 10:47 -
No audio when saving .MPEG file from VOB stream using MPEG Streamclip?
By Bix in forum MacReplies: 3Last Post: 25th Jul 2010, 17:12 -
Avi to MPEG-2 quality encoding mission
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 3Last Post: 31st Aug 2009, 01:10 -
Mpeg Streamclip and Final Cut Pro .mpeg...Only 1 hour clips?
By checksum in forum MacReplies: 10Last Post: 16th Dec 2008, 23:38
