ok i have movie a and movie b i want to get the audio from movie a and remove the audio from movie b and put movie a's audio on movie b please help
Load movie a into virtualdub and save wav,then load movie b in vdub and click on audio/audio from other file and open the wav you just created and then save as avi,make sure video is set to direct stream copy before you save as avi.
ok now it is out of sync the words come out before there mouths move can i have a easy tut how to fix that
Before you save as avi wiith the new audio click on audio/interleaving and goto the audio skew correction and input the time you need to correct the sync,when you put in the numbers close the audio tab and play the movie in vdub and see if the audio syncs.
If it doesnt sync then go back to the audio/interleaving and put in numbers till it matches,just keep going back and play it till it matches.I think,therefore i am a hamster.
AVI with AAC audio to AVI with MP3 audio
By Neroon in forum Video ConversionReplies: 6Last Post: 30th Jun 2010, 08:15 -
ffmpeg choppy audio from large avi but not small avi source file
By cybertheque in forum Capturing and VCRReplies: 9Last Post: 13th Oct 2008, 15:38 -
Dual audio AVI to singl audio AVI.
By Benhermies in forum EditingReplies: 8Last Post: 20th Aug 2008, 20:44 -
Converting an AVI video with AC3 audio to an AVI video with MP3 audio
By rijulHKG in forum AudioReplies: 1Last Post: 15th Jul 2007, 00:23 -
Converting AVI to xvid AVI - Audio Sync Problem
By foochuck in forum Video ConversionReplies: 3Last Post: 4th Jul 2007, 23:22
