Hi,
I have been using an encoding method to convert video files (such as .mkv and .avi) to iPod .m4v format. Usually everything turns out ok.
However, I have found that in some cases, things don't go entirely to plan, in many .avi files i have tried to encode, I have found that I keep getting the following errors:
[mp3 @ 0x1928a30]mdb:496, lastbuf:0 skipping granule 0
Last message repeated 1 times
[mp3 @ 0x1928a30]mdb:496, lastbuf:0 skipping granule 1
[mp3 @ 0x1928a30]mdb:511, lastbuf:329 skipping granule 0
[mp3 @ 0x1928a30]mdb:511, lastbuf:329 skipping granule 1
[mpeg4 @ 0x1928070]Invalid and inefficient vfw-avi packed B frames detected
frame= 663 fps= 88 q=10.0 size= 1132kB time=27.57 bitrate= 336.4kbits/s
I do not understand what the "lastbuf:0 skipping granule" lines mean, and also the "invalid and innefficient vfw-avi B frames detected" line means.
Could someone explain this to me? and explain how to resolve this error?
It seems that every time this shows up (particularly the "invalid and innefficient etc... line), the video appears to jerk slightly around every second. And in other cases, I have found that the audio completely falls out of sync with the video (as far as minutes behind the video)
If its any help I'll give the ffmpeg lines I am using:
Code:ffmpeg -y -i "%encode_file%" -acodec libfaac -ab 112kb -ac 2 -vol %vol% -ar 44100 -vcodec libx264 -level 21 -aspect %aspect% -b 384kb -r %fps% -coder 0 -croptop %croptop% -cropbottom %cropbottom% -cropleft %cropleft% -cropright %cropright% -s %dimensions% -metadata title="%title%" -f psp -cmp +chroma -flags +loop -partitions +parti4x4+parti8x8+partp4x4+partp8x8+partb8x8 -deblockalpha 0 -deblockbeta 0 -refs 1 -sc_threshold 40 -flags2 +mixed_refs -qdiff 4 -qcomp 0.60 -complexityblur 20.0 -qblur 0.5 -g 250 -keyint_min 25 -subq 2 -me_range 16 -me_method dia -qmin 10 -qmax 51 -i_qfactor 0.71 -pass 1 -threads %threads% -t %encode_time% -ss %encode_start_position% "%output_file%.m4v" ffmpeg -y -i "%encode_file%" -acodec libfaac -ab 112kb -ac 2 -vol %vol% -ar 44100 -vcodec libx264 -level 21 -aspect %aspect% -b 384kb -r %fps% -coder 0 -croptop %croptop% -cropbottom %cropbottom% -cropleft %cropleft% -cropright %cropright% -s %dimensions% -metadata title="%title%" -f psp -cmp +chroma -flags +loop -partitions +parti4x4+parti8x8+partp4x4+partp8x8+partb8x8 -deblockalpha 0 -deblockbeta 0 -refs 3 -sc_threshold 40 -flags2 +mixed_refs -qdiff 4 -qcomp 0.60 -complexityblur 20.0 -qblur 0.5 -g 250 -keyint_min 25 -subq 8 -me_range 16 -me_method umh -qmin 10 -qmax 51 -i_qfactor 0.71 -pass 2 -threads %threads% -t %encode_time% -ss %encode_start_position% "%output_file%.m4v") else ( ffmpeg -y -i "%encode_file%" -acodec libfaac -ab 112kb -ac 2 -vol %vol% -ar 44100 -vcodec libx264 -level 21 -aspect %aspect% -b 384kb -r %fps% -coder 0 -croptop %croptop% -cropbottom %cropbottom% -cropleft %cropleft% -cropright %cropright% -s %dimensions% -metadata title="%title%" -f psp -cmp +chroma -flags +loop -partitions +parti4x4+parti8x8+partp4x4+partp8x8+partb8x8 -deblockalpha 0 -deblockbeta 0 -refs 1 -sc_threshold 40 -flags2 +mixed_refs -qdiff 4 -qcomp 0.60 -complexityblur 20.0 -qblur 0.5 -g 250 -keyint_min 25 -subq 2 -me_range 16 -me_method dia -qmin 10 -qmax 51 -i_qfactor 0.71 -pass 1 -threads %threads% -ss %encode_start_position% "%output_file%.m4v" ffmpeg -y -i "%encode_file%" -acodec libfaac -ab 112kb -ac 2 -vol %vol% -ar 44100 -vcodec libx264 -level 21 -aspect %aspect% -b 384kb -r %fps% -coder 0 -croptop %croptop% -cropbottom %cropbottom% -cropleft %cropleft% -cropright %cropright% -s %dimensions% -metadata title="%title%" -f psp -cmp +chroma -flags +loop -partitions +parti4x4+parti8x8+partp4x4+partp8x8+partb8x8 -deblockalpha 0 -deblockbeta 0 -refs 3 -sc_threshold 40 -flags2 +mixed_refs -qdiff 4 -qcomp 0.60 -complexityblur 20.0 -qblur 0.5 -g 250 -keyint_min 25 -subq 8 -me_range 16 -me_method umh -qmin 10 -qmax 51 -i_qfactor 0.71 -pass 2 -threads %threads% -ss %encode_start_position% "%output_file%.m4v")
I am fairly new to ffmpeg so I wasnt able to address this issue myself, and the batch script I am using with these options was not created by me personally.
Any help would be greatly appreciated as I am keen to resolve this error.
Results 1 to 1 of 1
ffmpeg output 2gb limit? Is there one? ffmpeg stops encoding h264 @ 2gb
By BrainiakZ in forum Video ConversionReplies: 14Last Post: 30th Mar 2011, 13:04 -
FFMPEG FLV from MOV RED5 flowplayer streaming issues
By Brandon Grossutti in forum Video ConversionReplies: 2Last Post: 7th Aug 2009, 17:02 -
AVI to AC3 conversion question --Aftern and FFMPEG issues
By eclipse95 in forum AudioReplies: 3Last Post: 9th May 2009, 02:50 -
ffmpeg encoding help
By guitarscn in forum Newbie / General discussionsReplies: 1Last Post: 21st Apr 2008, 17:11 -
issues using codecs wmv9 and wma9.1 in ffmpeg
By jcor in forum LinuxReplies: 1Last Post: 15th Oct 2007, 09:27
