On all encoding software the resolution for creating mpeg for vcd in NTSC is 352x240. Is it possible to capture an mpeg at 480x480 or even 640x480 and still be able to create a NTSC vcd that will play in any standalone dvd? Also, would making the resolution higher than 352x240 make the vcd picture quality better?
Going higher resolutions at the same bitrate will only lower the perceived quality. Any resolution other than 352x240 NTSC or 352x288 PAL will NOT be VCD compliant and may not play in all VCD players.
You can encode SVCD (480x480 @ 2Mbps), but that reduces the amount of video you can fit on a CD.
Setting Up Potplayer
By Moontrash in forum Software PlayingReplies: 48Last Post: 29th Sep 2019, 12:57 -
DVDPlayer B.L.E. setting?
By wiseant in forum DVD & Blu-ray PlayersReplies: 1Last Post: 23rd Jan 2009, 13:52 -
Setting up my equipment...?
By Gun in forum Newbie / General discussionsReplies: 1Last Post: 11th Sep 2007, 13:41 -
which setting should i use
By fruitpassion in forum Video ConversionReplies: 4Last Post: 23rd Aug 2007, 20:58 -
Setting up a network
By bballnut in forum ComputerReplies: 6Last Post: 2nd Jun 2007, 16:31
