Hi!
I've googled and tried out several programs to create a BD out of x264 based video that would play correctly on my Philips BDP3000.
I'm quite sure x264 makes the video freeze, although, on computer it plays just fine.
Two questions:
- How do I convert/encode an x264(H.264/AVC MPEG-4) video LOSSLESSLY into any (HD)format, like H.264, VC-1 or WMV, that would play on standalone BD player?
Preferably, preserving 5.1 DTS/AC3 and without increasing the file size too much.
- Are there, nowadays, any Blu-ray standalone players that support x264?
I think many would like to free up HDD and make playable discs out of quality movies they've got from, for example, the internet but that seems to be hard.
Any ideas? Thanks!
The x264 h264 video must be BD-compliant like correct video resolution/size and has correct encoding profile. Video freezes could also be because of the dvd/bd media.
What tools are you using? Try multiavchd, avchdcoder and uncropmkv to make it in correct resolution/size. -
First of all, thank you for your replies!
I've been using tsMuxer and some other tools, without really knowing what's the problem. I downloaded the above programs and they're absolutely brilliant!
At least, after creating and burning a test clip on a BR-RE and playing it on standalone player it worked great. It seems the problem, indeed, was about the resolution or something else but now there's no stutter nor freezing.
I had now idea resolution could cause this...
This is what I've been trying to do for the last 6 months, so thanks again!
I'll be back with my ignorant questions if there's more "unsolvable" problems.
how to add subtitle to X264 movies ?
By fibola in forum Authoring (Blu-ray)Replies: 10Last Post: 27th Jul 2010, 18:00 -
tool to create 300mb x264 mkv movies
By lordrt in forum Video ConversionReplies: 2Last Post: 17th Jun 2010, 13:45 -
Best way to replace an Audio Track on x264 Video Movies...
By erosoft in forum Blu-ray RippingReplies: 2Last Post: 4th Dec 2008, 10:25 -
I am viewing some movies. If BVOP is off. Would it not play on standalone?
By rocky12 in forum Newbie / General discussionsReplies: 14Last Post: 27th Nov 2008, 09:32 -
Converting x264 to xvid for dvp642 standalone player
By ch4757 in forum Video ConversionReplies: 19Last Post: 23rd Jul 2007, 13:44
