Hi, I read in this forum that the DVD player with DivX logo do not support HD divx.
so, my question is:
what is the maximum quality a normal DivX compatible DVD player can play?
Thank you very much.
ok so i can have a 720x480/576 with hi bitrate? 5000k por ex???
and other question...
is the video is widescreen? what do a have to do so the dvd player knows that and not strech up and down the image? -
That depends on the player and how high and for how long the bitrate approaches 5000. You'll just have to test. Many will stutter or freeze for a short time with highs that approach 5000 for a few seconds. Others will have no problems with it. In general, though, with modern players a max bitrate of 5000 should be OK.
For most players you'll have to resize from 720x480/576. For a 1.78:1 ratio movie, it might mean resizing to 720x400 or some such. Or a lower resolution such as 640x352.and other question...
No, if your player does the resize, then good. Not doing any resize at all (together with a high enough bitrate) results in the best quality of all.
yes, my players has the option... 4:3 or 16:9... so thats all. thanks manono.
x264 command line for max quality within Bluray spec?
By Asterra in forum Video ConversionReplies: 5Last Post: 5th Apr 2012, 16:22 -
Convert DVd to xvid avi best quality for max size 900mb
By selwyns2828 in forum DVD RippingReplies: 6Last Post: 10th Feb 2011, 18:02 -
Convert .vob to another format with max quality
By alexv305 in forum DVD RippingReplies: 7Last Post: 19th Jun 2010, 23:36 -
Easy MKV -> DVD application? Want 5.1 and max quality (4,4 GB or DVD9)
By bjorsa in forum Newbie / General discussionsReplies: 19Last Post: 3rd May 2010, 13:08 -
How to get max. quality while resizing video
By newnews in forum Video ConversionReplies: 4Last Post: 6th Apr 2008, 16:36
