Hi guys!.
I have ASUS P7131 HYBRID tv-tuner on my Desktop pc and i want a software that i can record from TV in Progressive mode.
I have found WinDVR3 that writes in that way, but recognizes only the Analogue Antenna.
So i want a application for the DVB-T.
The box inside it had the TOTAL MEDIA 3.5, but writes in interlaced mode.
Thanks in advaced
Results 1 to 12 of 12
The stream send by the broadcast station is interlaced and the software (Total Media) simply write on disk the stream like it was send. If you want progressive you have to do deinterlace the file. It can be done with external software (VirtualDub Avisynth) and later you should recompress.
I never used WinDVR but the analog broadcasting is always interlaced. -
Check these infos (via mediainfo) from 2 videos. One with WinDVR and the other with TOTAL MEDIA.
Code:D:\TVTUNER CAPTURE\WINTV\WinDVR TEST.mpeg Format : MPEG-PS File size : 17.6 MiB Duration : 30s 960ms Overall bit rate : 4 763 Kbps Video ID : 224 (0xE0) Format : MPEG Video Format version : Version 2 Format profile : Main@Main Format settings, BVOP : Yes Format settings, Matrix : Default Duration : 30s 560ms Bit rate mode : Variable Bit rate : 4 446 Kbps Nominal bit rate : 6 912 Kbps Width : 720 pixels Height : 576 pixels Display aspect ratio : 4:3 Frame rate : 25.000 fps Standard : PAL Resolution : 8 bits Colorimetry : 4:2:0 Scan type : Progressive Bits/(Pixel*Frame) : 0.429 Stream size : 16.2 MiB (92%) Audio ID : 192 (0xC0) Format : MPEG Audio Format version : Version 1 Format profile : Layer 2 Duration : 30s 960ms Bit rate mode : Constant Bit rate : 128 Kbps Channel(s) : 2 channels Sampling rate : 48.0 KHz Video delay : -16ms Stream size : 484 KiB (3%)
As you see with WinDVR the Scan type is Progressive. I want similar program that recognizes DVB-T of my card alsoCode:D:\TVTUNER CAPTURE\TOTAL MEDIA\TOTAL MEDIA TEST.mpg Format : MPEG-PS File size : 15.3 MiB Duration : 29s 720ms Overall bit rate : 4 321 Kbps Writing library : ArcSoft MPEG-2 PAL Video ID : 224 (0xE0) Format : MPEG Video Format version : Version 2 Format profile : Main@Main Format settings, BVOP : Yes Format settings, Matrix : Default Duration : 29s 720ms Bit rate mode : Variable Bit rate : 3 926 Kbps Nominal bit rate : 6 000 Kbps Width : 720 pixels Height : 576 pixels Display aspect ratio : 4:3 Frame rate : 25.000 fps Standard : PAL Resolution : 8 bits Colorimetry : 4:2:0 Scan type : Interlaced Scan order : Top Field First Bits/(Pixel*Frame) : 0.379 Stream size : 13.9 MiB (91%) Writing library : ArcSoft MPEG-2 PAL Audio ID : 192 (0xC0) Format : MPEG Audio Format version : Version 1 Format profile : Layer 2 Duration : 29s 328ms Bit rate mode : Constant Bit rate : 224 Kbps Channel(s) : 2 channels Sampling rate : 48.0 KHz Video delay : -9ms Stream size : 802 KiB (5%)
Ok, i ll ask different:
Someone tell me the right codec (I have Win XP SP3 and i already installed CCCP) and the software to recognize my tv-tuner and record in DVB-T mode -
You may try DVBviewer or ProgDVB. See more tools:
https://www.videohelp.com/tools/sections/digitaltv-dvb-hdtv -
Hi Docoptik ! I've got the same TV Tuner card but I don't use the bundled softs.
I use DVBDream v1.4i with ffdshow installed and drivers version 13.3.5.3.
As danno78 said, the stream send by the broadcast station is either interlaced or progressive depending on the source : movies are often progressive encoded and realtime video are interlaced (sometimes they are progressive but the picture less sharp). I can't be change unless by processing the video later.
What is your goal ? Authoring DVD or make avi, mkv, mp4 ? -
About the stream of the broadcast i thought that it was always progressive. My mistake.
BUT i don't understand how the same channel with the analogue antenna if i wrote it via WinDVR is progressive and then if i wrote it via ToatalMedia is interlaced.
I want to convert it later as Avi(Xvid). I am using Virtualdub for years and i know about the deinterlace filter, which i am using it when i use TotalMedia. Or if you suggest another way for the conversion.
P.S Today i have found this link: http://support.asus.com/download/download.aspxwhere you can doenload the 13.3.5.5 driver
Oh it's cool for the updated driver link, thanks
Maybe the answer for your question about interlaced or not via antenna cable is due to Totalmedia or WinDVR settings. When you capture into MPEG-2 you can choose the way the fields are interlaced or not at the end. And some softwares will deinterlace the picture before converting it into MPEG...
I understand that when you get progressive caps, you will convert them easier and faster than interlaced caps.
I use the same method as you with VirtualDub but I don't deinterlace with its internal filter (I use a filter called "DeinterlaceAreaBased.vdf" I forget where I took it ). If you are familiar with AviSynth, there's a better way for deinterlacing. Look at documentations. -
Ok. I finally managed to watch Digital TV with DVDViewer and to record.
I use ffdshow as video coder.
I want to ask how you set the bitrate of the recorded file. I mean i get this from mediainfo
Width is ok but i want to increase the bitrate. Can i do it from fddshow video Decoder configuration? Where i have to look?Code:Format : AVC Format/Info : Advanced Video Codec Format profile : Main@L3.0 Format settings, CABAC : Yes Format settings, ReFrames : 3 frames Duration : 18s 320ms Bit rate : 2 833 Kbps Width : 720 pixels Height : 576 pixels Display aspect ratio : 4:3 Frame rate : 25.000 fps Standard : PAL Resolution : 8 bits Colorimetry : 4:2:0 Scan type : MBAFF Bits/(Pixel*Frame) : 0.273 Stream size : 6.19 MiB (88%) Color primaries : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M Transfer characteristics : BT.601-6 525, BT.601-6 625, BT.1358 525, BT.1358 625, BT.1700 NTSC, SMPTE 170M Matrix coefficients : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
Thanks. -
You can't increase the bitrate of the recorded stream in DVB mode because you get what is sent by air. In fact, the soft is acting as it simply copies the video stream and the audio stream into a .ts file (or .mpg). You have a video file which is like a copy of the original sent source... and what MediaInfo gives to you is an approximate bitrate
Hybrid on mac,..
By Selur in forum MacReplies: 72Last Post: 7th May 2012, 00:47 -
video editing software on ASUS Eee PC
By helpmepls in forum LinuxReplies: 3Last Post: 10th Feb 2009, 05:51 -
By helpmepls in forum ComputerReplies: 2Last Post: 6th Feb 2009, 08:05 -
[color=blue]video oediting software for ASUS Eee PC (white ones)[/color]
By helpmepls in forum Newbie / General discussionsReplies: 1Last Post: 6th Feb 2009, 07:53 -
Asus My Cinema P7131 Hybrid Capture Card - No Audio or Digital Reception
By Duchess in forum LinuxReplies: 10Last Post: 5th Jul 2007, 06:55
