Results 1 to 27 of 27
    Feb 2008
    Argentina
    Hi there.
    I have a question...
    I have a MKV file, and I want to convert it to AVI, buy, without loosing any quality.
    I tried the SUPER converter, output set to AVI and direct stream video and audio.
    The software does this very quicky of course, but the final AVI file, the new one doesnt open in WMPlayer, nor Vegas (says Unknown), but DOES play in VLC player.
    What other converter can I use to do this for the AVI file not to be bad?
    Thanks!
  2. Why do you want to convert it?
    What video & audio codecs? use mediainfo
    Not all video & audio formats are compatible with AVI container
    Feb 2008
    Argentina
    convert it to insert it in vegas.
    i do use mediainfo.
    h264 ac3... may be the ac3 is the problem???
    Feb 2008
    Argentina
    still doesnt work with MP3 audio... any ideas?
  5. avc2avi , then avimux gui to mux audio, or import audio separately
    or tsmuxer to put into .m2ts
    Feb 2008
    Argentina
    ok... but why this SUPER converter doesn not work? thanks
    Feb 2008
    Argentina
    i tried avc2avi but it asks me where is the *.h264 file... i dont have one. I have a MKV...
  8. mkvextract to extract raw video
  9. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    As poisondeathray mentioned, not every video and audio format out there is compatible with the AVI container. The h.264 AVC video that's common in MKVs these days isn't, to the best of my knowledge. The ac3 audio might not be compatible as well, but I couldn't say for sure.
    Yes, use MKVExtractGUI to extract the raw video stream from the MKV. Be sure to install mkvtoolnix and MKVExtractGUI to the same folder.
    Also note that the video stream will probably extract as a file with the extension .264, as I recall, or another extension avc2avi isn't expecting. Just rename the extension.
    Feb 2008
    Argentina
    Yeah I did that, Ai.
    I rencode the h264 file to xvid 720x480 16:9, i have the audios streams that came with the mkv.
    but now, my DTS stream wont play in WMP, nor my dvd player. but DOES in VLC.... any idea how to do this?
    I think my dvd player plays dts!
    Feb 2008
    Argentina
    it plays the AC3 files though....
    Feb 2008
    Argentina
    i made a new vid with virtualmod ... with the xvid and only the dts audio stream, and it doesnt play in my dvd player......
    any idea?
  13. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Run the video you just created through GSpot or MediaInfo (in Tree View) and post the resulting information here (a screenshot of the resulting GSpot window, for GSpot). Blank out the file and folder names, if you want.
    Note that standalone DVD players that can play DivX/Xvid are usually very picky about the videos you can play on them. Some of the conditions you'll probably want to make sure the video doesn't exceed can be found in this post.
    If you're not sure whether or not your DVD player supports DTS in AVI (heck, I'm not sure that's valid in an AVI, myself, which may be why WMP and some other players refuse to play it - VLC is also designed to allow playing of damaged/incomplete AVIs, and may just be valiantly playing what it finds (it can certainly play both those audio and video formats...)), try re-encoding the audio stream to a standard stereo MP3 and see if the player doesn't refuse it.
    Feb 2008
    Argentina
    Ok this is the screenshot:
    I saw the post of divx conditions.
    Now my method is this:
    installed:
    Virtualdub, Super converter, MKVextract y el Mkvtoolnix
    1. wizard of mkvextract to h264 and separeted audio files
    2. change extention to *.264
    3. avc2avigui to get into AVI.
    Now I have the AVI with no AUDIO.
    4. Compress to xvid, small to 720x480 16:9 with Super.
    xvid 6000k (but leave the new xvid avi file with 2000k dont know why)
    720x480 16:9,
    Audio DISABLE.
    5. Virtualmod - no xvid compression, but to add audio streams. the original ones, DTS and AC3s.
    In my DVD player, the DTS appears on the audio list channels, but its not played.
    I also try to make a 1000k xvid, to test, because of that post you gave me with common problems.
    So... I could use the PopCorn audio converter and convert DTS to AC3, but I dont wont that. I want the
    original audio in my new xvid...
    waiting for an answer please...
    thanks.
  15. Try remuxing with AVI-Mux GUI
    Feb 2008
    Argentina
    lets see...
    Feb 2008
    Argentina
    with the AVI-Mux GUI when i add the avi xvid file, the dts and the ac3, it ask me the name of the MKA file.... dont understand... i need an AVI file with the DTS and the AC3 audio streams
  18. Member
    Feb 2008
    Argentina
    sorry . i had it worked. i needen to press "generate data source from files" and the AVI was made.
    But
    the DTS file is not audible... no sound.
    The DTS file alone, is. In WMP.
  19. What model is your DVD player ? Does it support DTS?
    Open the AVI file in graphstudio, what does it show? What decoder are you using for DTS on PC? (e.g. AC3Filter, ffdshow etc...)?
    Feb 2008
    Argentina
    Yes it does!!! LG dv397h ... i have the manual, i found it 5min ago, and the dts is supported in DivX play...
    Feb 2008
    Argentina
    i only installed k lite codec pack full, divx 7, xvid for win 7...
  22. Member
    Feb 2008
    Argentina
    in graphstudio it says AC3Filter in green box...
  23. Member
    Feb 2008
    Argentina
    I will wait for an answer... thanks anyway.
  24. Member
    Feb 2008
    Argentina
    no help for me? uuu
  25. Member
    Feb 2008
    Argentina
    i suppose i will have to convert the DTS to AC3 then... uuuu
  26. Member [_chef_]'s Avatar
    Nov 2002
    Germany
    Hi there.
    Thanks!
    Stop using illegal downloads and you wont have all those issues.
    *** Now that you have read me, do some other things. ***
  27. If you have video and audio that are valid in an avi container then use VirtualDub with the mkv plugin http://home.comcast.net/~fcchandler/Plugins/Matroska/index.html to open the mkv file.
    Select Direct Stream Copy on video and audio, and save your avi file.
