Hi,
I am having problems exporting footage from premiere6 back to DV. The files capture fine and making a hard copy on my drive it all looks great. But when I start to export I get horrid digital breakups and stutters on the DV tape in the camera every 4 seconds or so, I have no idea what could be causing this other than maybe lack of memory or cpu?? The system I am running is win98se 128mb amd athlon with well over 20gigs free on the drive. Any ideas would be welcomed.
the footage is watchable but just with stutters so not very professional
Go to Project-> Project Settings -> General -> Playback Settings and turn off Playback on Desktop.
They system needs to take all the resources to go out to DV and not produce a copy on the monitor. This should fix it! -
Thanks for the suggestion. Have tried this but still no luck! any other ideas or reason welcomed.
It seems to play fine in the preview just when the camera is trying to record it does it all go jerky -
Gee, it sounds exactly like what happens when you try to monitor on the desktop while outputting to tape. I would suggest you post the same problem on the adobe forum.
Exporting HDV with Premiere Pro 2
By HDVth in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 9th Mar 2011, 15:41 -
exporting from premiere: progressive or interlaced ?
By codemaster in forum EditingReplies: 12Last Post: 5th Jan 2011, 01:57 -
Premiere CS4 lossless exporting
By timwizard in forum EditingReplies: 7Last Post: 16th Feb 2010, 10:49 -
When exporting out of Premiere...
By bsuska in forum Video ConversionReplies: 20Last Post: 4th Jan 2010, 18:22 -
Render before Exporting in Premiere Pro
By newsphotog in forum EditingReplies: 1Last Post: 29th Sep 2009, 11:39
