Hi all,
My cousin wants to re-purpose her old Macbook 3rd generation laptop as a HTPC. The problem is that the only port I can access on her TV is the side-accessible HDMI port; she won't let anyone remove it from the wall -- not even professionals -- because she's worried it might get damaged.
This means that I need to find her some sort of adapter/box that will let me merge the Macbook's video and audio together into HDMI
The Macbook has a Mini-DVI port. There are adapters available that will convert Mini-DVI to either DVI or HDMI video.
Audio could come from either the headphone jack -- which according to the manual outputs both analog and digital audio -- or a USB audio adapter.
Is there something that would let me merge DVI or HDMI with the audio sources? The only type of cable that I've found that does this takes DisplayPort or mini-DisplayPort, not mini-DVI, not DVI, not HDMI.
Thanks in advance for your help,
Phil
IMO: Better to use a networked Video player. Cheaper in the long run.
But such devices exist (this one requires S/PDIF and has poor reviews).
http://www.amazon.com/DVI-I-Dual-Converter-SPDIF-Audio/dp/B0015YYOQQ
This one would be more likely to work but the price far exceeds a networked player.
http://www.gefen.com/kvm/dproduct.jsp?prod_id=3570Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Any thoughts about the products listed here? (I found it after googling a bit)
http://www.avsforum.com/avs-vb/showthread.php?t=1135094 -
I have no first hand experience with any of them.
Dvi-hdmi audio question
By sanosuke in forum ComputerReplies: 1Last Post: 4th May 2011, 10:05 -
Plug DVI/HDMI adapter to DVI video card?
By Stealth3si in forum Media Center PC / MediaCentersReplies: 25Last Post: 23rd Dec 2010, 19:32 -
HELP please Avermedia A316 Mini PCI-E Analog Digital DVB-T TV Card
By Jorocketoz in forum Capturing and VCRReplies: 0Last Post: 26th Jun 2010, 00:05 -
Need help with HDMI, DVI-HDMI and "high definition audio device"
By uart in forum Newbie / General discussionsReplies: 7Last Post: 16th Mar 2010, 00:15 -
How can I use DVI analog inputs and HDMI from Cable box?
By hamiltonpl in forum DVB / IPTVReplies: 3Last Post: 15th Jan 2009, 20:28
