I have shaw HDTV cable box and I like to connect to my 1080p lcd monitor (LG w2353v).
Monitor has hdmi, dvi, and vga connection and cable box has dvi, rca, coaxial connection.
So I tried using dvi to dvi connection and I get message saying "dvi out of range".
whats the meaning of "out of range"?
Is this even possible? or have I done something wrong?
Thank you in advance.
"shaw HDTV cable box" is a Mototola? Sci Atlanta? Other? What is the box model number?
I can't find any info that the LG w2353v accepts interlace video. Most computer monitors don't. The cable boxes usually only output 1280x720p and 1920x1080i. So I suggest you try setting the cable box to 720p first. See if that works. Then try 1080i. Try it with DVI/HDMI and/or with analog component cable.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Its Motorola DC6200.
Hmm...since I get no display....I can try to change the setting in regular TV set.
Thanks for quick response. -
On the box locate the Power, Menu and Cursor buttons.
1. Power = Off
2. Press Menu, press left arrow until it shows "16:9"
3. Press down arrow once.
4. Press left arrow until it shows "720p"
5. Press Menu once.
Now when you turn power on it should be in 720p 16:9 output mode.Recommends: Kiva.org - Loans that change lives.
Thank you very much...it worked nicely.
720p works...1080i doesnt.
one more thing...
can I hook this up(hdtv box) and computer ? and switch back and forth? -
Connect LCD monitor to Digital HD Cable box?
By rogerconnery in forum DVB / IPTVReplies: 84Last Post: 18th Jan 2012, 07:04 -
TV Tuner Box and HD Computer Monitor
By Sparky24 in forum DVB / IPTVReplies: 4Last Post: 22nd Oct 2010, 18:41 -
How to connect a monitor to a digitanl cable box?
By Latvian in forum DVB / IPTVReplies: 3Last Post: 3rd Dec 2008, 01:47 -
A $19 Box will get you on HDTV
By SingSing in forum DVB / IPTVReplies: 66Last Post: 2nd Oct 2008, 22:22 -
Problems with connection with my Panasonic HDTV and Timewaner HDTV box...
By S4one in forum DVB / IPTVReplies: 7Last Post: 2nd Nov 2007, 23:39
