I inherited an Ariston iView USB capture box. It seems that primarily it was aimed at Mac users, but also had drivers for Windows 9x.
The box says it has 'hardware compression' Still the drivers install seem to be only capture (no video hardware codec). It seems to work, except that it won't let me select custom capture sizes (using latest virtualdub).
If I want to capture from VHS with the goal of being VCD, should I capture at 640x480 and then resize to 352x240 ? Otherwise, I can only capture at 320x240...
TIA.
Results 1 to 1 of 1
iView 102DV media player
By pudgym29 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 1st Nov 2011, 13:14 -
Which hdtv's have a USB port, so you can plug in a flash drive or USB HDD?
By snafubaby in forum DVB / IPTVReplies: 8Last Post: 30th Nov 2010, 17:03 -
Question about deleting USB drivers to fix lack of USB notification
By jimdagys in forum ComputerReplies: 13Last Post: 15th May 2010, 11:24 -
Cinergy 400 USB & pcmcia»USB 2.0 difficulties
By AEN007 in forum Capturing and VCRReplies: 0Last Post: 4th Mar 2009, 02:21 -
Can a usb mass storage mp3 player and usb harddrive coexist in vista?
By yoda313 in forum Off topicReplies: 3Last Post: 5th Aug 2007, 19:23
