Wondered if u could help me, Ive been using TMPGEnc for a while now, but recentally when i try to make a DVD From a AVI
its not smooth, every 3seconds theres a slight jump, and its annoying to watch, .. now im guessing its the framerate thats not in sync, but how do i fix this.? on a normal Avi its usually 23fps, do i just up that to 25fps or 29fps to solve it.?
Or is it just a problem with TMPGEnc.? while we are on the subject, Which is the best DVDAuthor program?
I like TMPGEnc cos its simple but i cant use it if its jerky!!
Cheers..
Closed Thread
You never mentioned that originally. Have you tried that same DVD disc on your PC?
As DVD has specific framerates (25 PAL, 29.97 NTSC, 23.976 NTSC with pulldown - see WHAT IS DVD on left menu) if may be you've converted a non-standard disc that a PC can cope with but a hardware player can't!
Trev
Post a mediainfo of the source avi and the encoded VOB. You say the avi plays smoothly on the PC, but you don't say if the converted DVD does as well.
My guess, based on the very little information you have given, would be a bad format conversion from NTSC to PAL. Chances are your DVD player will play both, so you should keep NTSC source material as NTSC when converting to DVD.Read my blog here.
Thanks for the replies, .. First, i converted a HD HOME MVK to DVD and it was jumpy, ( i did this one at work too on another computer using TMPGEnc thats why i assumed it was TMPGEnc) then ive tried to convert the new Avatar avi and its still jumpy,
although i did download a avatar dvd that someone else had converted and it WASNT jumpy . soo, all it seems to lead to is TMPGEnc .? Or .. am i wrong .?
Ive uploaded a mediainfo of the Avatar avi ..
Cheers ..
Depending on how tmpgenc does the conversion. I know that ConvertXtoDVD and AVStoDVD used the pulldown method for 23.976 fps to 25 fps material, so no jumpiness. Conversion of 29.970 fps material will either drop frames or ghost frames to get down to 25 fps.
In any case, format conversion should be a last resort measure. If your player can handle NTSC, keep it NTSC.
And don't talk about warez in the forum.Read my blog here.
HELP! ASAP! Conversion .VOB to .AVI videos are jumpy!
By AngelVideo in forum Video ConversionReplies: 4Last Post: 20th May 2011, 19:36 -
wmv to avi (divx/xvid) conversion jumpy output file
By famine99 in forum Video ConversionReplies: 5Last Post: 14th Oct 2007, 12:09 -
By famine99 in forum Video ConversionReplies: 0Last Post: 11th Oct 2007, 22:04 -
DVD to AVI file Jerky Jumpy
By Dolfin the Mammal in forum DVD RippingReplies: 8Last Post: 21st Aug 2007, 11:47 -
jumpy windows media player - avi
By bufalo in forum Software PlayingReplies: 3Last Post: 27th Jul 2007, 15:07
