Ok I have been using sefy vcd templetes for awile
they work great
great quality and everything
i can fit a movie up to 90min on one cd with great quality
now what my question is is that sometimes when a movie is like 120mins
and i have to put them on 2cds anyway
ill have like 60mins on one cd and 60mins on another
how can i max out the quality when i just have 60mins of video on a cd??
I used the bitrate calculator and raised the bitrate using constant
but i did not see any difference in quality
could someone help me with the settings so that I can max quality on a 50-60min movie
basically i guess i making a xvcd
please help
Y2Flyy
If you are happy with the quality of a 90 min movie using Sefy's templates,then why change the setting for 2- 60 min cd's?
b/c wee im happy with the quality but i just wanted to know if i could better the quality by raising the bitrate or any other settings when i have to put it on 2 cds anyway
Well, you could just increase the Bitrate in the Template, and that will improve the quality, or I would suggest you use a optimized SVCD Template instead, might give you a higher boost in quality, after all, my SxVCD or SeVCD are based on VCD settings only.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician.
Bitrate question and two pass question
By cyberlion in forum EditingReplies: 17Last Post: 11th Oct 2010, 12:17 -
Help with HF200 (24p and 30p question) technical question
By Coldbricks in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 15th Jun 2010, 14:24 -
Mod16 question and DAR question...
By alcOre in forum Newbie / General discussionsReplies: 5Last Post: 31st Oct 2008, 16:18 -
Age old question of VHS to DVD question...I still don't get it.
By saywhat? in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2008, 23:43 -
Sefy's Guide and Correct Setting for DVD (NTSC).mcf
By moviebuff2 in forum Newbie / General discussionsReplies: 8Last Post: 1st Aug 2007, 10:01
