Hello everyone
I'm using Adobe Premire Pro CS4 to create a video slideshow (photos + music). I don't have much previous experience with that and I'm quite new to Premiere.
I'm trying to create a widescreen video (16:9). In my initial setting I chose DV PAL Widescreen 16:9 (1.4587) I believe, then I import my photos and I "Interpret Footage" to the same PAL Widescreen 16:9 setting. However, when I try to export the video (i use video codec DV - PAL) the video file looks more like a 4:3 instead. When I check the Source and Output tabs before exporting the video looks exactly the same size in both (16:9), but comes out different. Apart from that the picture aspect ratio is correct and the quality seem to be good too. What am I doing wrong here? How can I fix this?
Any help much appreciated
Results 1 to 11 of 11
I should probably add that the video is both intended for Desktop preview in higher quality and for YouTube
Does the image look squashed in from the sides, or stretched vertically ? It could be that Premiere isn't properly flagging the video as 16:9, or that your player is ignoring the flag.
Is there a reason why you would output to DV format ?
Unless you are outputting back to DV tape, I would use a better suited format. If you only need desktop and youtube playback, output with a 1:1 pixel aspect ratio (i.e. no need for a 16:9 flag), probably using H264 for video.Read my blog here.
Thanks for the reply. This is how the image looks like http://www.photoplasticon.net/Files/video.jpg, the first pic is the way it looks in Premiere and the second how it looks after export.
There is no reason in particular why I used DV, except for it has the widescreen size I desire and I don't know what other settings to use. I don't know how to get the 1:1 pixel aspect ration or what it does, maybe you could be more specific?
I do want the final output to be a widescreen video.
PAL widescreen at 1:1 is 1024 x 576
As for your images, the first appears to be in a 16:9 from, but is horribly distorted. The second shows the photo as it should look, but in a 4:3 output.
For the moment, create a custom project with a resolution of 1024 x 576, add your images, then output to something like AVC (H264) without marking it 16:9Read my blog here.
also, using premiere cs4 to make a slideshow is sort of like torture. you could use a dedicated slideshow app like proshow or even free software like dvdslideshowgui
It seems like whatever setting I use the video comes out wrong. It looks ood in Premiere now and when it's processed it looks good in the Media Encoder as well, but when I open the ready file it's 4:3 and looks disorted
hi greymalkin, I'm a Mac user and the programs you listed are for Windows, I was kinda hoping that it would be more straight forward to do it in Premiere :/ -
ahh I see. well I did a little digging and found this for Mac:
foto magico
http://www.boinx.com/fotomagico/overview/
These application designed specifically for creating photo/video slideshows are waaaaay easier to use than making it in premiere...I've tried both ways and I'd never go back to premiere for that purpose
I checked out different programs, but in the end I decided to make the slideshow in iMovie. It was pretty easy to do, but looking at the end results, I feel that Premiere gives you a lot more control over the whole project. I always like to fine-tune and adjust every detail. I guess this will do for now
Thanks for everyones help
[beta] Bolide Slideshow Creator - Free AVI/MKV/WMV slideshow maker
By bolide in forum EditingReplies: 5Last Post: 30th May 2012, 03:18 -
Photo to Video? Slideshow
By patmann03 in forum Newbie / General discussionsReplies: 1Last Post: 17th Feb 2011, 09:24 -
Picture and Video Slideshow
By junkets in forum Software PlayingReplies: 0Last Post: 24th Aug 2010, 22:37 -
Video like a JPG slideshow
By ranosb in forum Newbie / General discussionsReplies: 9Last Post: 11th Jul 2009, 17:38 -
App to create slideshow as video???
By vulcan4d in forum Newbie / General discussionsReplies: 5Last Post: 20th Jan 2008, 20:56
