I am suddenly stuck.
I have quite a number of free and other programs like DVD Shrink, TMPGEnc, DVDFab6, as well as Pinnacle Ultimate 12.
I want to copy numerous clips from home dvds and with photos make a dvd using Pinnacle for my daughter's 21st.
I tried DVDFab, but Pinnacle did not recognize the format, so did DVD Shrink(I converted a lot of video tapes to DVD using my DVD hard drive recorder.
Any advice please?
Results 1 to 10 of 10
What kind of dvd is it? it could be dvd-vr, dvd-ram and then it might not be that easy rip from. Check what folder and files you see on the dvd.
Studio can import directly from a DVD (at least v11 Plus) - go to: File - Import DVD Title
John, I only received your post after my post.
So, I import the DVD and will then be able to cut clips? -
That is a standard dvd and it should work to import directly in pinnacle as johnp mentions.
It looks as if my problem is solved- Pinnacle has started to capture.
Thanks for the prompt advice
Albie -
Some of these DVDs are importing quickly (the ones I wrote directly from the DVD recorder), but the ones I made using "TMPEnc" with "GUI for DVD Author" struggle to upload. The last one is taking at least two hours and not finished yet.
So I was wondering if anyone knows of a program that would convert DVD (vob files) to MPEG, which I then could use in Pinnacle?
Albie
How to cut out clips from DVDs and convert to AVI, MP4 using free software
By Baldrick in forum User guidesReplies: 13Last Post: 13th Dec 2016, 20:33 -
Combine clips in Sony Vegas (NOT GROUPING!!)
By Compo in forum EditingReplies: 31Last Post: 7th Jan 2014, 16:00 -
Extract video from 2 home DVDs - combine to single DVD with menus
By gutted in forum Newbie / General discussionsReplies: 5Last Post: 24th Apr 2011, 15:31 -
How to Combine MP4 Clips and then to WMV & AVI
By gonwk in forum Video ConversionReplies: 3Last Post: 2nd Mar 2010, 09:35 -
want to combine flv clips
By shashgo in forum Newbie / General discussionsReplies: 3Last Post: 10th Mar 2009, 13:34
