My laptop (Acer) keeps shutting down constantly. I've noticed that the times that is shutting down are the times when I use messenger + webcam + surf on the internet...so basically when it's overloaded...
Any idea what might be the issue?
How is it shutting down? Blue screen or just turning completely off?
Checked it for overheating with something like Hardware Monitor? http://www.cpuid.com/hwmonitor.php
Does it give you an error code? -
or a driver issueare the times when I use messenger + webcam + surf on the internet
CPU, processor cooling fan, processor cooling fan controller, motherboard, power supply board, main battery - or the aforementioned driver issue. I suspect it's more likely a hardware issue, but laptops are not my strong suit. While I and the family own several, including some netbooks: I would not enjoy the prospect of taking another one apart to troubleshoot it. I did have a Compaq years back that I had apart several times over various issues - won't buy another after HP bought Compaq.
;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep" -
If this only started recently, I would say that it is because of heat. With the laptop on, see if you are getting adequate airflow out of the vents. Dust clogs up the heatsink vents all the time, resulting in emergency power downs, initiated by the CPU.
ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W
Computer keeps shutting down
By mac71671 in forum ComputerReplies: 8Last Post: 29th Jan 2010, 09:45 -
By didikai in forum Newbie / General discussionsReplies: 22Last Post: 31st Aug 2008, 08:24 -
Folders keep shutting down?
By aelfheah in forum Newbie / General discussionsReplies: 12Last Post: 26th Feb 2008, 14:07 -
laptop randomly shutting down
By Tbag in forum ComputerReplies: 11Last Post: 20th Jun 2007, 00:42 -
Nero Keeps Shutting Down
By DuBsTaR in forum Newbie / General discussionsReplies: 3Last Post: 21st May 2007, 11:41
