I've been using ffmegx for years to convert avi files to DVDmpeg2enc with subtitles burned in. The resulting TS folder is then burned to a DVD so I can play it on a stand alone DVD player. Two weeks ago, some of the avi files which I had previously converted to TS folders now only show green when played in quicktime (or when the icon is shown in the Finder). However, the files still play in their entirety in VLC. Have not yet resolved the Quicktime green screen problem. Other avi files are able to be encoded and play just fine--it's just a select few--and even within a series of files, some are green while others are fine.
Have tried to take those same avi files and again create TS folders. Mplayer plays them fine with both sound and subtitles when I preview them in ffmpegX before encoding, but the resulting TS folder plays green for 5 seconds with no subtitles and a burst of sound in the last second.
The Process Information is really, REALLY long--here's the beginning:
this is the part where things seem to go wrong:Encoding started on Fri Feb 5 18:13:03 HST 2010
movtoy4m
Copyright 2002-2006 Johan Lindström
All rights reserved..
INFO: [yuvscaler] yuvscaler 1.9.0 (15-02-2004) is a general scaling utility for yuv frames
INFO: [yuvscaler] (C) 2001-2004 Xavier Biquard <xbiquard@free.fr>, yuvscaler -h for help, or man yuvscaler
INFO: [mpeg2enc] SETTING EXTENDED MMX for MOTION!
INFO: [mpeg2enc] SETTING SSE and MMX for TRANSFORM!
INFO: [mpeg2enc] SETTING EXTENDED MMX for PREDICTION!
INFO: [yuvscaler] input: frame size: 720x480 pixels (518400 bytes)
INFO: [yuvscaler] input: chroma: 4:2:0 JPEG/MPEG-1 (interstitial)
INFO: [yuvscaler] input: frame rate: 30000/1001 fps (~29.970030)
INFO: [yuvscaler] input: interlace: none/progressive
INFO: [yuvscaler] input: sample aspect ratio: 1:1
INFO: [yuvscaler] from 720x480, take 720x480+0+0, NOT_INTERLACED/PROGRESSIVE
INFO: [yuvscaler] scale to 720x480, 720x480 being displayed
INFO: [yuvscaler] Scaling uses the RESAMPLE algorithm,
INFO: [yuvscaler] frame rate: 29.970 fps
INFO: [yuvscaler] Scaling ratio for width is 1 to 1
INFO: [yuvscaler] and is 1 to 1 for height
INFO: [yuvscaler] Specific downscaling routing number 4
INFO: [yuvscaler] output: frame size: 720x480 pixels (518400 bytes)
INFO: [yuvscaler] output: chroma: 4:2:0 JPEG/MPEG-1 (interstitial)
INFO: [yuvscaler] output: frame rate: 30000/1001 fps (~29.970030)
INFO: [yuvscaler] output: interlace: none/progressive
INFO: [yuvscaler] output: sample aspect ratio: 1:1
INFO: [mpeg2enc] Selecting DVD with dummy navigation packets output profile
INFO: [mpeg2enc] Assuming norm NTSC
INFO: [mpeg2enc] Encoding MPEG-2 video to /Users/kathy/Documents/Retina.E03.avi.ff.m2v
INFO: [mpeg2enc] Horizontal size: 720 pel
INFO: [mpeg2enc] Vertical size: 480 pel
INFO: [mpeg2enc] Aspect ratio code: 2 = 4:3 display
INFO: [mpeg2enc] Frame rate code: 4 = 30000.0/1001.0 (NTSC VIDEO)
INFO: [mpeg2enc] Bitrate: 4000 KBit/s
INFO: [mpeg2enc] Quality factor: 3 (Quantisation = 3) (1=best, 31=worst)
INFO: [mpeg2enc] Field order for input: none/progressive
INFO: [mpeg2enc] New Sequence every 9999 Mbytes
INFO: [mpeg2enc] Assuming non-video stream of 0 Kbps
INFO: [mpeg2enc] Search radius: 16
INFO: [mpeg2enc] DualPrime: no
INFO: [mpeg2enc] Using one-pass rate control
INFO: [mpeg2enc] GOP SIZE RANGE 7 TO 15
INFO: [mpeg2enc] Setting colour/gamma parameters to "NTSC"
INFO: [mpeg2enc] Progressive format frames = 1
INFO: [mpeg2enc] Using default unmodified quantization matrices
INFO: [mpeg2enc] SETTING MMX and MMX for QUANTIZER!
INFO: [mpeg2enc] PAR = 1
INFO: [mpeg2enc] Creating worker thread 0
INFO: [mpeg2enc] NEW GOP INIT length 15
INFO: [mpeg2enc] Worker: getting
INFO: [mpeg2enc] Working: stripe 0/1 1
INFO: [mpeg2enc] Worker: stripe 0 done
INFO: [mpeg2enc] Enc1 0 0( 0) I q=5.29 [100% Intra]
Any suggestions would be greatly appreciated!INFO: Video pts = 0.133 .. 3721.284
INFO: Audio[0] pts = 0.133 .. 5.157
INFO: Audio[32] pts = 0.133 .. 3721.265
STAT: VOBU 7435 at 174MB, 1 PGCS
INFO: Generating VTS with the following video attributes:
INFO: MPEG version: mpeg2
INFO: TV standard: ntsc
INFO: Aspect ratio: 4:3
INFO: Resolution: 720x480
INFO: Audio ch 0 format: ac3/6ch, 48khz drc
STAT: fixing VOBU at 1MB (17/7435, 0%)
STAT: fixing VOBU at 2MB (33/7435, 0%)
STAT: fixing VOBU at 3MB (49/7435, 0%)
STAT: fixing VOBU at 3MB (65/7435, 0%)
STAT: fixing VOBU at 5MB (81/7435, 1%)
STAT: fixing VOBU at 6MB (97/7435, 1%)
STAT: fixing VOBU at 7MB (113/7435, 1%)
STAT: fixing VOBU at 8MB (129/7435, 1%)
STAT: fixing VOBU at 8MB (145/7435, 1%)
STAT: fixing VOBU at 8MB (161/7435, 2%)
STAT: fixing VOBU at 9MB (177/7435, 2%)
STAT: fixing VOBU at 9MB (193/7435, 2%)
STAT: fixing VOBU at 9MB (209/7435, 2%)
STAT: fixing VOBU at 9MB (225/7435, 3%)
STAT: fixing VOBU at 10MB (241/7435, 3%)
STAT: fixing VOBU at 10MB (257/7435, 3%)
STAT: fixing VOBU at 10MB (273/7435, 3%)
STAT: fixing VOBU at 11MB (289/7435, 3%)
STAT: fixing VOBU at 11MB (305/7435, 4%)
STAT: fixing VOBU at 12MB (321/7435, 4%)
STAT: fixing VOBU at 12MB (337/7435, 4%)
STAT: fixing VOBU at 12MB (353/7435, 4%)
STAT: fixing VOBU at 12MB (369/7435, 4%)
STAT: fixing VOBU at 13MB (385/7435, 5%)
STAT: fixing VOBU at 13MB (401/7435, 5%)
STAT: fixing VOBU at 13MB (417/7435, 5%)
STAT: fixing VOBU at 14MB (433/7435, 5%)
STAT: fixing VOBU at 14MB (449/7435, 6%)
STAT: fixing VOBU at 14MB (465/7435, 6%)
STAT: fixing VOBU at 15MB (481/7435, 6%)
STAT: fixing VOBU at 15MB (497/7435, 6%)
STAT: fixing VOBU at 15MB (513/7435, 6%)
STAT: fixing VOBU at 16MB (529/7435, 7%)
WARN: audio sector out of range: -8203 (vobu #538, pts 269.402)
WARN: audio sector out of range: -8227 (vobu #539, pts 269.902)
WARN: audio sector out of range: -8252 (vobu #540, pts 270.403)
WARN: audio sector out of range: -8259 (vobu #541, pts 270.903)
WARN: audio sector out of range: -8266 (vobu #542, pts 271.404)
WARN: audio sector out of range: -8273 (vobu #543, pts 271.904)
STAT: fixing VOBU at 17MB (545/7435, 7%)
WARN: audio sector out of range: -8280 (vobu #544, pts 272.405)
WARN: audio sector out of range: -8287 (vobu #545, pts 272.905)
WARN: audio sector out of range: -8294 (vobu #546, pts 273.406)
WARN: audio sector out of range: -8301 (vobu #547, pts 273.906)
WARN: audio sector out of range: -8317 (vobu #548, pts 274.407)
WARN: audio sector out of range: -8333 (vobu #549, pts 274.907)
WARN: audio sector out of range: -8350 (vobu #550, pts 275.408)
WARN: audio sector out of range: -8366 (vobu #551, pts 275.908)
WARN: audio sector out of range: -8394 (vobu #552, pts 276.409)
WARN: audio sector out of range: -8420 (vobu #553, pts 276.909)
WARN: audio sector out of range: -8448 (vobu #554, pts 277.410)
WARN: audio sector out of range: -8474 (vobu #555, pts 277.910)
WARN: audio sector out of range: -8500 (vobu #556, pts 278.411)
WARN: audio sector out of range: -8526 (vobu #557, pts 278.911)
WARN: audio sector out of range: -8552 (vobu #558, pts 279.412)
WARN: audio sector out of range: -8578 (vobu #559, pts 279.912)
STAT: fixing VOBU at 17MB (561/7435, 7%)
Kathy
Mac OS 10.5.8 on a 2.8 GHz Intel Core 2 Duo
4 GB SDRAM
Quicktime Pro 7.6.4
Green screen is usually a decoding error, like when a video codec isn't (fully) recognized/supported.
Is it possible that you didn't select the same decoder for the files that encoded well and those that didn't?
If you would select 'Decode with mplayer' for one file and 'Decode with Quicktime' for another, or neither (which in effect falls back to decoding with ffmpeg), then the results may differ.
I've been doing it the same each time and don't usually select a decoder (use most of the default settings). In ffmpegX, I assumed that I had to use mplayer. The only time I used Quicktime is if I want to check a clip and play it to check audio/video quality (not within ffmpegx). Just got two new clips now and they both came in showing only green--will try them in ffmpegX to see if I am able to get them to encode. This is all too strange.
With QT, I also have Perian, DivX, MPEG Streamclip, but none of them work with these clips. <sigh> Don't recall adding any codecs recently (I wouldn't know what to add).
Check what the Summary in ffmpegX says about the video and audio on AVIs that converted and didn't convert okay. (No need to convert, just opening the source file.) I think there might be an important difference there between the files, like an unusual codec.
First of all, thank you VERY much for staying with me on this. I learn so much about this app by just problem solving and that takes me a step further every time! I also learn new features of ffmpegx which I never knew before, such as the INFO and PLAY button at the top of the window (duh). Not sure which information you are talking about, but here's what I found:
Summary of Source format for the green screen file:
Video: mpeg4, yuv420p, 640x352
Audio: mp3, 48000 Hz, stereo, 192 kb/s
VIDEO: [XVID] 640x352 12bpp 29.970 fps 1241.5 kbps (151.6 kbyte/s)
audiocodec: framecopy (format=55 chans=2 rate=48000 bits=0 B/s=24000 sample-576)
Summary of Source format for a file that converted successfully:
Audio: ac3, 48000 Hz, stereo, 192 kb/s
VIDEO: [XVID] 624x352 24bpp 29.970 fps 1360.2 kbps (166.0 kbyte/s)
audiocodec: framecopy (format=2000 chans=2 rate=48000 bits=0 B/s=24000 sample-768)
Now that my curiosity's piqued, here's file from a different series that converted successfully:
VIDEO: [XVID] 640x360 24bpp 29.970 fps 1349.7 kbps (164.8 kbyte/s)
audiocodec: framecopy (format=55 chans=2 rate=48000 bits=16 B/s=24000 sample-1)
Hmmmm, I'm stumped.
Avidemux Green Screen
By FrozenInferno in forum Video ConversionReplies: 4Last Post: 2nd Apr 2011, 23:31 -
TMPGEnc green screen
By BobAchgill in forum Newbie / General discussionsReplies: 3Last Post: 18th Jun 2010, 17:06 -
Underwater Green Screen
By kccannon in forum EditingReplies: 6Last Post: 21st May 2009, 20:35 -
Funny green screen
By timmythesaint in forum Newbie / General discussionsReplies: 18Last Post: 14th Apr 2009, 15:41 -
encoding mpeg4 with ati MMC results in green video
By toomanyblastedbits in forum Capturing and VCRReplies: 1Last Post: 6th Oct 2008, 02:39
