Ok so I'm new here but I have a Dazzle DVC 100 capture card but id does not allow me to play my games in HD and I'm beginning to get headaches by not being able to play in HD when I want to record my games. What capture card could I buy that would allow me to play my games in HD? Please help.
Hauppauge HD-PVR
It will loop 1080i or 720p analog component to your TV. Hardware encoding is to h.264 over USB2.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
AverMedia also makes an HD capture device. I have no idea how well it works but it's a lot cheaper than the Hauppauge HD PVR.
http://www.avermedia.com/avertv/product/productdetail.aspx?id=499
http://www.amazon.com/Avertv-Definition-Analog-Capture-MTVHDDVRR/dp/B002SQE1O0
I believe it uses software compression so you'll probably need a beefy system to capture HD.
And the BlackMagic Intensity Pro can capture both HDMI (as long as it's not HDCP protected) and component video.
http://www.amazon.com/Blackmagic-Design-Intensity-Editing-Express/dp/B001CN9GEA/
Those amazon reviews of the BlackMagic Intensity Pro are scary. Can it be true that it won't work on an i7 box?!
xbox 360 capture card?
By blindman96 in forum Capturing and VCRReplies: 7Last Post: 26th Mar 2011, 20:56 -
Xbox 360 Capture Card
By 23000 Empire in forum Newbie / General discussionsReplies: 2Last Post: 13th Jul 2010, 08:51 -
Capture Card xbox 360
By Mastapka53 in forum Capturing and VCRReplies: 2Last Post: 27th Mar 2010, 13:50 -
By Dr Awesome in forum Capturing and VCRReplies: 2Last Post: 19th Feb 2010, 05:06 -
Best capture card for xbox 360?
By Edward1982 in forum Newbie / General discussionsReplies: 2Last Post: 28th Jul 2009, 15:53
