Hello all,
I'm new here and hopefully won't make a fool of myself. Sincere apologies if this has been addressed before. If so, please point me to the right answer???
I'm trying to convert a 3gp file to something that can be played most universally, mpeg, avi maybe.
When I try all the available stuff like Any Video Converter, Movavi, Womble MPEG Editor, I get about the first 25% of video converted and then nothing. What do I need to do. Have Windows Vista and plenty memory and processing power.
rokeeffe....
Your source file might be damaged. Does it stop at the same place?
h264 MP4 is a safe bet for playability.
The only assured format for playing everywhere is Mpeg1"Quality is cool, but don't forget... Content is King!" -
No, it's different with each option I use. And it plays fine on the Reganam 3gp player. Go figure.
OK, so what's h264? Forgive my ignorance. And which converter do u recommend as best?
If you want simple, try WinFF. If you want lots of options, try xvid4psp
h264 is a video compression technology that's very popular. Movies that you can watch on an iPod are h264 encoded.
There are many ways to compress a video file. You can use DivX, h264, mpeg, etc. These are called codecs - Compress/Decompress. You compress the file when you convert it to a new format, such as h264, and you decompress it on the fly as you're playing it back on your computer.
Audio and video codecs reside inside a container, such as a 3GP, MP4 or AVI file
Universal Video format for streaming
By musomn in forum Video Streaming DownloadingReplies: 38Last Post: 30th Apr 2011, 03:34 -
H264/AMR file in .3gp format
By Jean777 in forum Newbie / General discussionsReplies: 1Last Post: 8th Apr 2010, 15:02 -
Most universal format for PC's
By skinnyneo in forum Newbie / General discussionsReplies: 3Last Post: 24th Mar 2010, 17:20 -
Universal encoding for random format videos ??
By lostnucleus in forum ffmpegX general discussionReplies: 3Last Post: 19th Oct 2009, 08:33 -
How to cut a 3gp file to part files without a format change?
By kop in forum Portable VideoReplies: 1Last Post: 22nd Oct 2008, 12:52
