Hi,
Apologies for the basic nature of this query- I am just starting out...!
I am trying to convert a VOB file to WMV but when I upload the video to the converter (have used Magic Video Batch Converter and iSkySoft Video Converter) it only converts the first 6 seconds of a video that is over 5-6 minutes in length. The size of the file that I'm uploading corresponds with a video 5-6 minutes long but both the converters seem to only pick up the first 7 seconds!
Has anyone experienced this before and can anyone help??
Any help gratefully appreciated,
P
Just try another converter like windows media encoder, wmvconvert or wmvmuxer.
Thanks for the responses.
I've just tried Windows Live Movie Maker and this has exactly the same problem (i.e. only shows first 7 secs of a movie I know is 5-6 mins long). What is really strange though is that if I drag the progress bar along the movie (which is says is only 7 seconds) I see frames from the full movie (all 5-6 mins) so I know it's there yet the duration of the film remains at 7 seconds and if I press play to preview the film, only the first 7 seconds are there....strange!! This is the same in all 3 converters I have tried so far!
Like I say, the file size also indicates that the movie is 5-6 mins long. It is a video of a bungee jump that I did a while back and I suspect that the first 7 seconds is 'generic library footage' of the bridge where I did the bungee, which they have added to the start of the video that was actually shot on the day- would this cause this issue?
Anyone got any further ideas???
cheers,
P -
You might be better off using VOB2MPEG on the .vob files from your footage - the .vob file you're trying to convert may not contain all of the footage, or have other things present that might be causing the converters to fail. A .vob file can be more than just an audio/video stream.
Once you have the MPEG(s) (VOB2MPEG won't re-encode the videos, if you're concerned), you can then pass them to whatever converter you prefer.If cameras add ten pounds, why would people want to eat them?
VOB or wmv to avi
By mauricemaurice in forum MacReplies: 10Last Post: 22nd Jun 2009, 13:03 -
questions regarding getting the best quality from converting VOB to WMV
By grannyklump in forum DVD RippingReplies: 3Last Post: 10th Jul 2008, 14:13 -
convert vob to wmv???
By pizzaplease in forum Video ConversionReplies: 5Last Post: 22nd Nov 2007, 07:17 -
VOB to WMV!!!!
By guitarparth in forum Newbie / General discussionsReplies: 5Last Post: 27th Oct 2007, 05:34 -
wmv to vob
By angryassdrummer in forum Video ConversionReplies: 1Last Post: 7th May 2007, 04:01
